Sun, Feb 2, 12:24 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara Free Stuff here.
Subject: Screenshots, for those brain fart moments cant find the tick-box
MistyLaraCarrara ( ) posted Fri, 09 July 2021 at 4:42 PM · edited Sat, 01 February 2025 at 10:07 PM
sometimes i can't remember where something is, more often these days, doh.
sharing here some quick reminder screenshots.
Adding content to Carrara Browser Tray
Add 'folder' for:
Carrara Native Content
Daz Studio Library
**Ds Library must contain the data folder at the top of the folder hierarchy. If you see the ds file not found message, its looking for the data folder,
Add 'runtime' for Poser content.
Objects
Shaders
Misc
Modifiers
Atmospheres for
Add Skies and Realistic Skies
Effects
To copy carrara browser tray to a new pc
copy over the preferences.txt file
this the win10 path to preference files
C:Usersyour windows10 user nameAppDataRoamingDAZ 3DCarrara 8.5
preferences.txt
somebody haz a mac path screenshot??
MistyLaraCarrara ( ) posted Fri, 09 July 2021 at 5:05 PM
Sometimes the DS Library doesn't find the .ds file, even though it's there.
sometimes deleting the DS library and re-adding doesn't fix it.
deleting the ds library thru the browser tray leaves a remnant in the preferences.txt file.
Can be anually deleted, so as to re-add it fresh and new.
open preferences.txt in a notepad editor.
look for the following lines and delete them
Look for AFOL and DSLib, delete it and the 3 lines under it.
Editing this file, can
change the order folders show in the tray.
for the subfolders, delete the index file and re-index from the browser tray.
for the top folders, manually reorder the folders in the preferences txt file.
MistyLaraCarrara ( ) posted Fri, 09 July 2021 at 5:27 PM
other things i brain fart on
Background
HDRI goes under background (not backdrop)
Sunbeams
Sunbeams are under, realistic, sky, in the fog tab (2nd button)
Rainbows
Rainbows are under sky (not realistic sky)
Camera dof
Camera depth of field previewer is under camers,effects
MistyLaraCarrara ( ) posted Fri, 09 July 2021 at 5:34 PM
Light Gels
light gels go under the light, effects, gel, map
Camera Minimum Distance,
before camera clipping occurs, is under camera, general, distance to near plane, has a minimum of .01
MistyLaraCarrara ( ) posted Fri, 09 July 2021 at 5:39 PM
stuck in the hair decision making process, doh, which way to go?
dyanmic hair should have a dedicated thread, by someone wo knows how to use it, lol
got so many furless furr babies
MistyLaraCarrara ( ) posted Fri, 09 July 2021 at 5:43 PM
sometimes my brain just refuses remember where the render alpha channel is.
its 2nd tab under render settings. >.<
MistyLaraCarrara ( ) posted Fri, 09 July 2021 at 6:04 PM · edited Fri, 09 July 2021 at 6:06 PM
Modifiers Lists
Complex
Behaviors
Waves
works on text primitive
Smart Pack
Basic Deformation
Physics
MistyLaraCarrara ( ) posted Fri, 09 July 2021 at 6:29 PM
Modifiers, Physics --> Soft Body, Soft Body Attached
3 places for Soft body settings
Modifiers Tab
Soft Body
Effects Tab
Physical Properties
Physics Tab
Physics Engine
MistyLaraCarrara ( ) posted Fri, 09 July 2021 at 6:32 PM
MistyLaraCarrara ( ) posted Fri, 09 July 2021 at 6:38 PM
Particle Emiiter presets
Particle Emitter, Obj, Shader Domain
example text primitive
MistyLaraCarrara ( ) posted Fri, 09 July 2021 at 6:40 PM
ROYGBIV RGB ref https://img.webnots.com/2015/05/Rainbow-5.png
MistyLaraCarrara ( ) posted Fri, 09 July 2021 at 6:47 PM
These tools I've ignored, cuz i don't know how to use em, it draws on the preview ball
Polygon Layer, rectangle layer
MistyLaraCarrara ( ) posted Fri, 09 July 2021 at 6:48 PM
MistyLaraCarrara ( ) posted Fri, 09 July 2021 at 6:54 PM
Convert Primitive to Vertex
On the edit menu
quick uv map, Box
Shader Domain Management
MistyLaraCarrara ( ) posted Fri, 09 July 2021 at 6:56 PM
DS screenshot,
Converting rigging General to Blended Weight or Triax
Edit, Figure, Rigging, Concverrt ...
MistyLaraCarrara ( ) posted Fri, 09 July 2021 at 7:00 PM
Gradient Shader
i forget where to find it
MistyLaraCarrara ( ) posted Fri, 09 July 2021 at 7:12 PM
Carrara native light gels
Barn Doors
MistyLaraCarrara ( ) posted Fri, 09 July 2021 at 7:16 PM
gradient shadow
setting a shadow map
MistyLaraCarrara ( ) posted Mon, 12 July 2021 at 8:15 AM
trivia do you know where to find the lens flare?
