Carrara F.A.Q (Last Updated: 2024 Sep 29 9:32 am)
Sometimes the DS Library doesn't find the .ds file, even though it's there.
sometimes deleting the DS library and re-adding doesn't fix it.
deleting the ds library thru the browser tray leaves a remnant in the preferences.txt file.
Can be anually deleted, so as to re-add it fresh and new.
open preferences.txt in a notepad editor.
look for the following lines and delete them
Look for AFOL and DSLib, delete it and the 3 lines under it.
Editing this file, can
for the subfolders, delete the index file and re-index from the browser tray.
for the top folders, manually reorder the folders in the preferences txt file.
♥ My Gallery Albums ♥ My YT ♥ Party in the CarrarArtists Forum ♪♪♪ 10 years of Carrara forum ♥ My FreeStuff
other things i brain fart on
stuck in the hair decision making process, doh, which way to go?
dyanmic hair should have a dedicated thread, by someone wo knows how to use it, lol
got so many furless furr babies
sometimes my brain just refuses remember where the render alpha channel is.
its 2nd tab under render settings. >.<
Modifiers, Physics --> Soft Body, Soft Body Attached
Physical Properties
Web dings reference for the Text Primitive
ROYGBIV RGB ref
These tools I've ignored, cuz i don't know how to use em, it draws on the preview ball
Oval layer
Polygon Layer, rectangle layer
Bones Influence.
On the edit menu
DS screenshot,
Converting rigging General to Blended Weight or Triax
Edit, Figure, Rigging, Concverrt ...
Gradient Shader
i forget where to find it
Barn Doors
setting a shadow map
trivia do you know where to find the lens flare?
sometimes i can't remember where something is, more often these days, doh.
sharing here some quick reminder screenshots.
Adding content to Carrara Browser Tray
Add 'folder' for:
**Ds Library must contain the data folder at the top of the folder hierarchy. If you see the ds file not found message, its looking for the data folder,Carrara Native Content
Daz Studio Library
Add 'runtime' for Poser content.
Objects
Shaders
Misc
ModifiersAtmospheres for
Add Skies and Realistic Skies
Effects
To copy carrara browser tray to a new pc
copy over the preferences.txt file
this the win10 path to preference files
C:Usersyour windows10 user nameAppDataRoamingDAZ 3DCarrara 8.5
preferences.txt
somebody haz a mac path screenshot??
