Poser 12 F.A.Q (Last Updated: 2024 Dec 22 9:02 pm)
CobraBlade posted at 2:40PM Tue, 01 June 2021 - #4420253
The good news is that Snarly is still as kind as ever and still working on updating his scripts for Poser 12.
And thank you for your help, sir :)
Free stuff @ https://poser.cobrablade.net/
hborre posted at 7:21AM Wed, 02 June 2021 - #4419572
For example, it has been found that the anisotropic setting was not working correctly in P12 Superfly, something that was corrected in the latest builds. I also believe that the specular node was not working as it should since P11 for Superfly, another feature that was actually broken for a long time and recently corrected. HDR background projection was broken in one of the builds, I was one of the first to report the problem. A good number of these problems have been posted in the forum and subsequently reported to the techs.
There was also an issue reported by me where, in early Poser 12, any Subsurface Scattering connected to an image was rendering green. Corrected.
Also a bug that Bagginsbill found by accident when trying to help me some time ago, in P11, that when you have the exact same value for two of the RGB channels in PhysicalSurface root's subsurface scattering values, it renders as if it were black. I don't think that one was ever addressed, but haven't tested it - a lot of Superfly issues have been corrected in the newest versions of P12.
Feel free to call me Ohki!
I've got some great news to share, Snarly's scripts are ready to be shared! You'll find them all here at poser.cobrablade.net, the new Poser 12 ones as well as his classic scripts for anyone still using earlier versions of Poser!
EZSkin for Poser 12 is still being worked on by Snarly, but even now will save anyone having to set up their scene in Poser 11 then re-opening it up in 12 just to still have access to the wonder script.
Poser scripts by Snarlygribbly
CobraBlade posted at 3:53AM Thu, 17 June 2021 - #4421474
Woohoo ?
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Win11 on i9-13900K@5GHz, 64GB, RoG Strix B760F Gamng, Asus Tuf Gaming RTX 4070 OC Edition, 1 TB SSD, 6+4+8TB HD
👿 Mac Mini M2, Sequoia 15.2, 16GB, 500GB SSD
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
Great to hear. Thanks
CobraBlade posted at 9:00AM Thu, 17 June 2021 - #4421474
Thank you! Thank you!! Thank you!!! You just made my day!!!!
_______________
The return of the EZDome, with its shadow catcher: wooooow.... Thank you so much @Snarlygribbly ❤❤❤
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
snarlygribbly.org/poser
Ooooops, this website is unavailable
redirected to suspended ?!
anyway, thank you for all the hard work you been doing, I sometimes use your older scripts. Skipping the new ones not a P12 owner, would be already a nightmare to convert the syltermermaid 900 ++ oops mean 800++ doll packs for poser 12 and this is just one collection of many. so sticking to your previous great Pythons.
thank you
!Firefly! posted at 1:12PM Fri, 18 June 2021 - #4421552
thank you
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
Rhia474 posted at 2:02PM Fri, 18 June 2021 - #4421557
It's a beautiful thing, innit? Had a crazy week, but the weekend should allow for installing and trying.
"Should allow"? let me think... nah... It's mandatory! ???
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
It's an honour to host them Snarly :) Hey ChromeStar, when I get a chance I'll look into adding some descriptions for each of the scripts.
CobraBlade posted at 9:41AM Sat, 19 June 2021 - #4421603
I updated the links in the directory. Thanks for the heads up, CobraBlade.
So, am futzing with EZSkin. It seems that at least with the skins of V4 and M4 that I tired so far, the lip definitions need to be manually changed to match the skin; otherwise there is a rather noticeable sharp delineation around and the colors, especially with M4, are just...not right.. Once that is updated, they look great; but so far I couldn't use the out of the box option alone (much like with the other skin script I tried, some values MUST be played with).
Example of V4 (with EZ Dome, one background drop and one light):
I've added pop-up descriptions over on poser.cobrablade.net for anyone that needed them.
While the Poser 12 version of EZSkin's script is up and running great, the shaders are the part still under development, so be sure to keep an eye on this space :)
CobraBlade posted at 10:11AM Mon, 21 June 2021 - #4421739
I suppose I should ask. Recently, I've undertaken adding more DS links to the Directory. So I'm curious to know, which scripts will or won't work in DS and preferably which version?
EClark1894 posted at 11:09AM Mon, 21 June 2021 - #4421761
These are Poser scripts Earl, so won't work in DS. Poser uses Python for it's scripting, and I'm pretty sure DS does not.
_______________
Google says this:
ECMAScript Language Daz Script 2 is a dynamically-typed, interpreted, object-oriented scripting language that is tightly integrated with the Daz Studio API . It is an extension of QtScript, which is an extension of ECMAScript as defined in the ECMAScript Language Specification (ECMA-262).
So, def not Python.
Rhia474 posted at 6:20PM Mon, 21 June 2021 - #4421782
Google says this:
So, def not Python.
I was going to say QtScript, as that's what I remember from when I was using DS, back in the day. I just wasn't sure if they had updated to something else since then.
_______________
From the official doc page:
V4.8.7: End-of-Life (as of December 2015). And the V6.2 is soon to be released. Looks pretty much like Poser's Python 2/3 problems. Reference: here.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
CobraBlade posted at 8:38AM Mon, 19 July 2021 - #4423227
I'm just wondering, is there anyone else using EZDome on macOS?
I will be using it as soon as I have it installed...
LA
This thread circled me back to D3D's script list
A word is not the same with one writer as with another. One tears it from his guts. The other pulls it out of his overcoat pocket
Charles Péguy
Heat and animosity, contest and conflict, may sharpen the wits, although they rarely do;they never strengthen the understanding, clear the perspicacity, guide the judgment, or improve the heart
Walter Savage Landor
So is that TTFN or TANSTAAFL?
Let me know if the shadow catcher renders as a misty field by default LostAlien. That's what I had with my testing, but it would be interesting to know if the same was for anyone using a Mac.
Hey JimTS, if you were looking for Snarly's scripts you can use this link poser.cobrablade.net
Thanks sorting thru which script to use between versions is causing a lot of dysfunction sorting error stalls in non flowing work blockage log jam of idea/images
Charles Péguy
Only the Poser 12 scripts at the top will run in Poser 12. With the legacy scripts, unfortunately, I never backed up older version of Poser so with Smith Micro out of the picture I only have access to Poser 12&11 so wouldn't be able to test if any of them stopped working after a specific version prior to 11.
don't most contemporary scripts still run in 11? Okay more than one native runtime/python directory at a time
Charles Péguy
You may even have a unique collection of scripts that works either with Poser 11 or Poser 12, and have at the same tîme the collection that adapts itself, using Poser's Python menu.
Example:
import poser
version = poser.AppVersion()
if version[0:2] < '12':
poser.DefineScriptButton(1, ":Runtime:Python:PoserScripts:ScriptsMenu:EZSkin3.pyc", "EZSkin3")
poser.DefineScriptButton(2, ":Runtime:Python:PoserScripts:ScriptsMenu:ezdome.pyc", "EZDome")
poser.DefineScriptButton(3, ":Runtime:Python:PoserScripts:Cyp:V11:Launch_Object_manager_P9.pyc", "Object Manager")
poser.DefineScriptButton(4, ":Runtime:Python:PoserScripts:ScriptsMenu:Utility:deleteLights.py", "Delete all lights")
poser.DefineScriptButton(5, ":Runtime:Python:PoserScripts:Cyp:XLC_V11:XLC.py", "Extended light control")
poser.DefineScriptButton(6, ":Runtime:Python:PoserScripts:ScriptsMenu:Netherworks:Material Tools:Transfer Material.py", "Transfer Material")
poser.DefineScriptButton(7, ":Runtime:Python:PoserScripts:Cyp:tools-v11:tools.py", "Tools...")
else:
poser.DefineScriptButton(1, ":Runtime:Python:PoserScripts:Cyp:tools-v12:layers-nodes:tools.py", "Mats/Nodes...")
poser.DefineScriptButton(2, ":Runtime:Python:PoserScripts:Cyp:tools-v12:lights:tools.py", "Lights...")
poser.DefineScriptButton(3, ":Runtime:Python:PoserScripts:Cyp:tools-v12:tools.py", "Tools...")
poser.DefineScriptButton(4, ":Runtime:Python:PoserScripts:Cyp:tools-v12:set_background_angle.py", "Background Angle")
poser.DefineScriptButton(5, ":Runtime:Python:PoserScripts:Cyp:snarly:tools.py", "Snarly's...")
poser.DefineScriptButton(6, ":Runtime:Python:PoserScripts:Cyp:tools-v12:WN_Cloth_Presets.pyc", "Cloth Presets")
poser.DefineScriptButton(7, "", "...")
poser.DefineScriptButton(8, ":Runtime:Python:PoserScripts:Cyp:Sasha-16:tools.py", "Sasha-16")
poser.DefineScriptButton(9, ":Runtime:Python:poserScripts:Cyp:ik:IK_mgt.py", "IK management")
poser.DefineScriptButton(10, ":Runtime:Python:PoserScripts:mainButtons.py", "Main...")
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
Also depends on what version of Poser a script was originally made for as Poser 12 isn't the 1st version of Poser to receive an updated Python engine.
