Sat, Feb 8, 6:55 PM CST
Renderosity Forums / Poser 12
Welcome to the Poser 12 Forum
Poser 12 F.A.Q (Last Updated: 2025 Feb 03 7:20 pm)
Subject: How do you "redock" the document window into its default position?
LionkingCMSL ( ) posted Thu, 29 July 2021 at 11:40 AM · edited Sat, 08 February 2025 at 6:54 PM
I've accidentally undocked the document window from its default position and can't seem to get it back.
I've done so before and ended up reinstalling Poser 12, which is something I'm loathed to do again, as I've quite a few libraries that I need to access.
So, is there an easy way to get the document window back to its default state without reinstalling Posser 12?
Y-Phil ( ) posted Thu, 29 July 2021 at 12:57 PM
Each window has a little control, on the top right:
And when you click on it:
Or did I missunderstood you?
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
!Firefly! ( ) posted Thu, 29 July 2021 at 1:12 PM
LionkingCMSL ( ) posted Thu, 29 July 2021 at 2:06 PM
@ Y-Phil and !Firefilefly!
I've tried both methods and neither worked.
Using the "Floating" method I still get the white bar across the top of the window with the close window "X" which is not there in its default setting. Using the "Factory Pre-set" only resets the scene and lighting. It does not reset the windows.
I thank you for your advice.
Y-Phil ( ) posted Thu, 29 July 2021 at 2:17 PM
LionkingCMSL posted at 2:16PM Thu, 29 July 2021 - #4424170
Then, would you mind to share a printscreen of the whole?
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
LionkingCMSL ( ) posted Thu, 29 July 2021 at 2:23 PM · edited Thu, 29 July 2021 at 2:24 PM
I have found a way to re-dock the document window. Instead of selecting "Launch to Factory Scene" under the document tab, I needed to go to the Interface tab and select "Launch To Factory State", which keeps my scene settings the way they were, but resets the interface windows.
Now it's the simple task of closing those windows I don't use or need.
I do thank !Firefly! for putting me on the correct path.
!Firefly! ( ) posted Thu, 29 July 2021 at 2:38 PM · edited Thu, 29 July 2021 at 2:46 PM
Cool you found it guess I had the wrong tab open LOL
RedPhantom ( ) posted Thu, 29 July 2021 at 4:10 PM
Site Admin
now that you have it fixed, open your UI memory dots, if they aren't open, and save one so if you mess it up again, all you have to do is click on one dot to fix it. If they aren't open, they're just over halfway down the windows menu. Hotkey is ctrl, shift, m.
hborre ( ) posted Thu, 29 July 2021 at 5:36 PM
Y-Phil's method works fine with me. I came across it on my own.
RobZhena ( ) posted Thu, 29 July 2021 at 6:59 PM
I would set a memory dot to the default setting in every room you use. I accidentally screw up the UI every so often and finally learned that hard lesson.
randym77 ( ) posted Fri, 30 July 2021 at 6:33 AM
LionkingCMSL posted at 6:29AM Fri, 30 July 2021 - #4424174
I'll have to try this. I ran into the same problem, and could not re-dock it. I assumed it was a Poser 12 bug, since it's never happened in Poser 11, but has happened repeatedly in Poser 12. I've been just letting the window float, at the same size and position that it used to be docked.
Snarlygribbly ( ) posted Sat, 14 August 2021 at 1:30 PM
Hi, I've only just noticed this thread! I wrote a script a while ago to fix this problem, as it annoyed me too. The script re-docks the document window and changes NOTHING else. I'll get CobraBlade to add it to his site.
Free stuff @ https://poser.cobrablade.net/
randym77 ( ) posted Sat, 14 August 2021 at 2:51 PM
You're a miracle-worker, Snarly! Thanks!
Faery_Light ( ) posted Wed, 01 September 2021 at 6:39 PM
I wish they would make it default to have the "Don't drag" and the floating or drag and drop as options. I have to run snarly's script every time I re-open Poser.
So Renderosity, how about doing an update for Poser and fixing those pallets so they are docked by default? :)
hborre ( ) posted Wed, 01 September 2021 at 7:21 PM
I don't understand why you need to run the script every time you open Poser when the app actually remembers the preference upon shutdown. Just uncheck Drag-Docking enable and you're done. If you don't feel comfortable with that procedure then just save your settings through General Preferences or create a UI Dot. Guaranteed, unchecking Drag-Docking enable and the window will not move from its docked position.
Faery_Light ( ) posted Wed, 15 September 2021 at 5:09 PM
Wow, this thread was a huge help! Now i know more how to handle that docking issue. :)
NikKelly ( ) posted Sun, 26 September 2021 at 7:12 PM
Thank you. I've not met this problem, but I've learned something new against a future 'Murphy Bomb' such as low-flying cat..
Autumn has arrived, the cats are eating for twice their number: On cool evenings, 'Ms Robbie the Ratter', our tabby huntress, will come in from patrol, leap onto my desk, march to-and-fro purring, then sprawl across my right arm. Fortunately, I use a track-ball...
hborre ( ) posted Sun, 26 September 2021 at 7:21 PM
LOL!!
McGrandpa ( ) posted Tue, 05 October 2021 at 10:56 PM
P12 clearly don't like RE-docking its panels.  I was going to suggest using a UI dot when you have it set up nice.   Saved me lots of trouble!
My 66th Birthday PC Build (July 1, 2020) :  named BadMoonRYZEN!, W10Pro x64, Octal Core RYZEN7 X3700 4.05 GHz, 64GB DDR4 RAM, GeForce RTX 3060 - 12GB GDDR6, PP2014, PP 11, P12, PS-CS4 Extended & Vue 2024.
McG.
