DAZ|Studio F.A.Q (Last Updated: 2025 Jan 02 6:48 pm)
If I understand correctly what your issue is try this. I had this happen when I installed a freebie, it change my default setting and once I found the culprit I uninstalled it and it fix my problem. . Load your figure and with it selected got to the parameters tabs: select actor: then people: and scroll down the list looking for anything that's not 0%. In your case this item looks to be set to 100% once you find it set it to 0% and that should clear your problem. If you don't uninstall it will have to be re-accomplished every-time you load your item. If it's not there then you'll have to go through each list under actor tab until you find it. Good luck.
Your load times on G8F may being impacted by the number of morph packages / characters you have installed. I would uninstall any ones that you aren't using / have no plan to use. I would also check your error log after the load to see if you have any errors coming up.
As already mentioned, there is a good chance you have a character installed that defaults into your G8F. This is a common problem overlooked by DAZ3D's quality control. Once one of these incorrect products are installed they are always dialed into your G8F figures no matter what. When the issues are pointed out DAZ3D usually resolves them, but creating the ticket report is a pain in the neck.
