Tue, Nov 26, 7:40 AM CST
DAZ|Studio F.A.Q (Last Updated: 2024 Nov 26 6:59 am)
Subject: jpg of G8f and G8.1f
goofygrape ( ) posted Fri, 30 July 2021 at 2:33 AM · edited Tue, 26 November 2024 at 5:37 AM
goofygrape ( ) posted Fri, 30 July 2021 at 2:36 AM · edited Fri, 30 July 2021 at 2:37 AM
top one is after loading new skin bottom as loaded, this is after a new install of G8f and G8.1f, no alteration as I know of. Any morphs stuck on I will need some help to fix that(what to look for etc.)
BlackStarr42 ( ) posted Fri, 30 July 2021 at 12:29 PM
If I understand correctly what your issue is try this. I had this happen when I installed a freebie, it change my default setting and once I found the culprit I uninstalled it and it fix my problem. . Load your figure and with it selected got to the parameters tabs: select actor: then people: and scroll down the list looking for anything that's not 0%. In your case this item looks to be set to 100% once you find it set it to 0% and that should clear your problem. If you don't uninstall it will have to be re-accomplished every-time you load your item. If it's not there then you'll have to go through each list under actor tab until you find it. Good luck.
jestmart ( ) posted Fri, 30 July 2021 at 3:55 PM
Clicking Currently Used will show all non zeroed morphs.
goofygrape ( ) posted Fri, 30 July 2021 at 10:10 PM · edited Fri, 30 July 2021 at 10:12 PM
all I can say now is Wow thank's I'll do as instructed also it takes hours to load G8f and G8.1 G3f minutes
JasonGalterio ( ) posted Sat, 31 July 2021 at 8:30 AM
Your load times on G8F may being impacted by the number of morph packages / characters you have installed. I would uninstall any ones that you aren't using / have no plan to use. I would also check your error log after the load to see if you have any errors coming up.
As already mentioned, there is a good chance you have a character installed that defaults into your G8F. This is a common problem overlooked by DAZ3D's quality control. Once one of these incorrect products are installed they are always dialed into your G8F figures no matter what. When the issues are pointed out DAZ3D usually resolves them, but creating the ticket report is a pain in the neck.
goofygrape ( ) posted Sat, 31 July 2021 at 2:19 PM
thank you all for your time and ideas, I found two morphs set at 100% but not the problem, this was LY Rory body and LY Rory head.G8f looks like herself now. :)
RHaseltine ( ) posted Sat, 31 July 2021 at 3:43 PM
The problem with LY Rory was fixed soon after release, as I recall. Redownload from your product library/through Install manager/through Daz Studio (depending on install method used) and it should be OK.
goofygrape ( ) posted Tue, 03 August 2021 at 1:55 AM
will do
