You can try before you buy! There's a free 21 day trial.
https://www.posersoftware.com/downloads
Whether it's worth it depends on what you use Poser for. It renders in Superfly much faster, so if you use Superfly, it's probably worth it.
OTOH, there are drawbacks. A lot of Python scripts that work in older versions of Poser don't work in Poser 12. (Python 2 reached its end of life, meaning Poser 12 had to use Python 3.) Some older scripts are being converted, but not all. The simple tab in the Material Room is gone, so if you used that, you might miss it. There are a few bugs they are still working on.
You can keep both Poser 11 and 12 at the same time, and they will open each other's files, so you can have both if you want. (That's what I do.)
There is a list of some changes on the purchase page here
These are some changes that might not be listed there
Removal of combine figure, find unseen polygons and reduce poligons, Path Palette from figure menu
Removal of Path Palette from object menu
Removal of path palette, keyframe category list from windows menu
Update python to version 3
Remove links to websites from help menu, many of which are now closed
Faster superfly renders
Updated cycles render engine
Added denoiser
Added adaptive sampling to superfly
Added post effects to superfly
Added choice to render over background image or transparent background
Simple tab in materials room changed to assign tab. It allows you to add an mt5 material file to multiple material groups at once.
Option when switching an image in the image node, the image texture node in cycles, or the environment texture node to change the same image for all instances of the image in that material group, any material for that figure, or for the entire scene.
Updated nodes for updated cycles.
Added principled bsdf and prinsipledhair bsdf nodes
Improved search function in library
Search Renderosity and Posersoftware stores from library
Purchases tab includes content and purchases from Posersoftware as well as Renderosity marketplace. It is not required to use this, but it is available.
Some of these might be duplicates of the market place listing. I didn't compare my list with it too closely.
As randym77 said, there is a 21 day trail you can chack it out and see if the changes are for you.
If you need scripts and non-photoreal, Poser 11. If you want the latest-greatest-fastest photoreal on your latest-greatest-fastest graphics card (and don't care about scripts), then Poser 12. But as others have said, they should work together on the same PC. Bear in mind also that Poser 12 is still in Early Access, which means you should be wary about relying on for a major new project. Things break, get fixed, break again.
emjay247 - I thought DSON died with the Smith Micro versions of Poser, due to the Python upgrade from 2.7.1 to 2.7.17. How do you have DSON import running on Poser 11.3? Did perhaps the Mac version of 11.3 not get the Python upgrade that Windows got?
Ah, thanks. Great. Fantastic news for all Poser 11 users, then.
RedPhantom posted at 10:21PM Fri, 13 August 2021 - #4425223
What?!? They removed Combine Figure and Reduce Polygons? Why? Those features would be the only reason I would ever upgrade (I certainly would never use Poser 12 now knowing this, maybe Poser 11 if that's the last version that will support these features).
RedPhantom posted at 11:08AM Tue, 17 August 2021 - #4425223
Added denoiser
THANK YOU !!
Artist @ajmarti.com
Hi guys I own Poser 11 already. but I got a new iMac so I'm thinking of gettin POSER 12... Does it worth it? Or should I stay with POSER 11? Please give me your opinion.. I've seen some people having problems with 12 version
Thanks!
Artist @ajmarti.com
