Tue, Nov 19, 12:26 AM CST
Renderosity Forums / Poser 12
Welcome to the Poser 12 Forum
Poser 12 F.A.Q (Last Updated: 2024 Oct 22 2:54 pm)
Subject: Fitting Rom issue: clothing rips apart after posing figure
Varnayrah ( ) posted Sat, 27 November 2021 at 6:16 AM · edited Mon, 18 November 2024 at 10:41 PM
Hi,
I've a curious issue with the fitting room. I've tried different clothing items now to fit to La Femme, but always the same problem occured. I fitted the item according to the poser pulse short tutorial except I didn't always use auto group. The item seemed fitted well enough after turned into a new figure, but when conformed to La Femme and applied a pose to La Femme, the clothing item would ripp apart at various places.
Like in this instant: clothing item is the Little devil Dress by Aery Soul, and that rips appart between waist and hip:hFIPNbAeKmday8WXc8XWT1aog1lq2LF00qz6O0aX.jpg
I tried fiddling around in the joint editor, but to be honest i don't know at all what to do there. Also copying joint centers from La Femme to the dress after conforming did not help. Any ideas? There are quite some older things I'd like touse for La Femme. And of course there ist the flash challenge *gg*
RedPhantom ( ) posted Sat, 27 November 2021 at 8:32 AM
Site Admin
While I've seen this between the legs because poser doesn't like more than 2 groups together and there you ended up with 3, I've never seen it at the waist and hip. I'm assuming copied the joint zones since that usually gives more distortion. Where I'd try would be to make sure the skinning method is set to unimesh under the figure>skinning method and then make sure both joints have the bending checked on the properties tab.
Varnayrah ( ) posted Sat, 27 November 2021 at 8:33 AM
This is a work-aroundwith fitting the dress to the morphed and posed La Femme and then spawning it as a prop, that works well enough. Must be in the process in generating a figure from the fitting session...2QA2D7UHBvbUcLeHVkiuocdWsPdmLbuF2mltTBPs.jpg
hborre ( ) posted Sat, 27 November 2021 at 9:13 AM
I've just tried the Little Dyvil dress with La Femme in the Fitting Room and I don't see any issues with the mesh tearing when posing.  I did use the Prefitter to transfer the La Femme morphs to the dress and then run it through the Fitting Room.  My recommendation is to Auto Group the dress when saving it as a figure.  Also, untick the body parts that are not relevant to the dress, for example, the Head, the forearms, the shins, etc.
Varnayrah ( ) posted Sat, 27 November 2021 at 9:47 AM · edited Sat, 27 November 2021 at 9:49 AM
RedPhantom posted at 8:32 AM Sat, 27 November 2021 - #4430945
Thank you, I#ll look into this next try...
hborre, I tried deleting unnneded body parts, didn't change a thing. Might try it with the prefitter, though (but where do I find that?)
hborre ( ) posted Sat, 27 November 2021 at 10:22 AM
On this page, you will find both the Prefitter-CR2 Basic and the La Femme add-on injector.  I've used it on numerous occasions with a rather good success rate.  And right now, both are on sale.
 https://www.renderosity.com/rr/mod/bcs/vendor/FVerbaas
hborre ( ) posted Sat, 27 November 2021 at 10:38 AM
La Femme, posed, with the Little Dyvil Dress after a quick process with the Prefitter-CR2 to fit the dress to the model and then into the Fitting Room.  In the Fitting Room, make sure the object (Dress) has zeroed and keep deformations checked; run with the Prefit selection and create a new figure.  On some occasions, the Prefitter-CR2 fit could be exact so all you would need to do is just create the figure without prefitting the clothing.  Auto Grouping is essential, you want to match figure zones as closely as possible.
Varnayrah ( ) posted Sat, 27 November 2021 at 11:07 AM
Now I feel really stupid. I have that prefitter and forgot all abput it...
hborre ( ) posted Sat, 27 November 2021 at 11:38 AM
Happens.  How many times I've overlooked the obvious.
Varnayrah ( ) posted Sun, 28 November 2021 at 1:04 AM · edited Sun, 28 November 2021 at 1:04 AM
...and using the prefitter indeed did the trick. Beats me way it should work better than with just the fitting room, but I'll take it as it is. The fit is better, too, I think, it would just need some touch up with the morph tool in the crotch area.
Y-Phil ( ) posted Sun, 28 November 2021 at 7:20 AM
Varnayrah posted at 1:04 AM Sun, 28 November 2021 - #4430968
I've had the same issues while trying to convert a dress originally made for Terai Yuki: the number of iterations also influences the effect on the part near the crotch while prefitting
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Mac Mini M2, Sonoma 14.6.1, 16GB, 500GB SSD
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
