Blender F.A.Q (Last Updated: 2024 Nov 17 9:25 pm)
Thanks for this Lobo, as I've seen auto retopology mentioned, but hadn't seen anything specific about it, so this will be interesting for sure.
_______________
My Free Models
My Video Tutorials
My CG Animations
Instagram: @luxxeon3d
Facebook: https://www.facebook.com/luxxeon
My recent model of the Hibernation Chamber in my gallery I tried both the Voxel and Quad remesh with in Blender left me with odd topology (the Voxel was a bit better than the Quad but not by much) that did not UV map very well and I did use the Zremesher in Zbrush and it gave me excellent topology and from my understanding and I could be wrong but heard that Quad Remesher addon was developed by the same person who created Zremesher. But on a lark I tried the IGL's Instant Mesh which is a free external app and I got similar quality remesh as Zremesher. The Hibernation Chamber before remesh 146,176 tris after Zremesher 9,653 tris now the main reason for such a high polycount while modeling this was uwsing metaball modeling
Lobo3433
That looks great, Lobo! Yeah, the Instant Mesh app is good, but I'm not a huge fan of it for lower poly results. It can provide a useable geometry for static models or some objects that aren't too complex with large flat surface areas. I haven't found it very good for more organic or complex surfaces because it tends to produce strange edge loop terminations and ngons at lower resolutions. It takes some work to get a good result from it at lower resolutions. In some cases, I can just retopologize better geometry on a surface with 3dCoat in less time.
You are correct in that the Zremesher was created by the same person who developed the Exoside technology. I've been using the Exoside or Zremesher solutions for a couple of years now and they really do a great job in most cases. There are some objects that I made via boolean or high poly sculpting that I wanted to retopologize for distribution. I tried to do it by hand but it was extremely difficult and time-consuming because of the various interlocking parts and curvature on each object. The only thing that was capable of doing the job reasonably well was Zremesher/Exoside. Well worth the money in my opinion if you do a lot of retopology.
My Free Models
My Video Tutorials
My CG Animations
I agre LuxXeon the Zremesher is fantastic and have looked at the Exoside but currently finding a suitable work flow using Blender's GOB add-on for Zbrush I think I am ok with and since most of my stuff is non-organic usually I do not have to remesh often have done a decent job with keeping poly counts pretty reasonably but now that I am looking at other modeling options like using Booleans I know that remeshing is something I will need to do more since Applications like Poser and even Daz do not handle NGons at all and retopo is becoming more important even to get textures to look good. I did see with in the video above that he showed some techniques for helping to get better results using IGL's Instant Mesh for more organic models. I think Blender 3.0 is going to be like coming out to becoming a more mature 3D software even saw a boost in my render time with Cycles X and I am still on a GTX 980Ti
Lobo3433
Cycles X is really fantastic for both Nvidia and AMD GPU now. It really shines for Optix-enabled cards (RTX), but they've also improved CUDA. Moreover, they've really made an effort toward supporting AMD cards as well, with HIP framework support for RDNA architecture and Radeon Pro drivers. It's a massive leap forward in GPU rendering capability in Blender.
My Free Models
My Video Tutorials
My CG Animations
OK, a quick question Lux, you mention Optix-enabled cards (RTX), but I'm wondering if Optix will work with my GTX 1660 card, which runs on the same Touring system as the RTX cards. Do you have any ideas about that?Cycles X is really fantastic for both Nvidia and AMD GPU now. It really shines for Optix-enabled cards (RTX), but they've also improved CUDA.
_______________
I do not think my old GTX 980 can take advantage of the Optix been trying to get a RTX card but just been impossible to find one that is reason and with in a fair price range will keep on looking can just imagine the further speed boost I would see with a newer card in my system.
Lobo3433
Optix requires a GPU with compute capability 5.0 and higher, and a driver version of at least 470, according to the Blender specs. Optix is currently ONLY supported by the RTX cards in Blender. There is speculation it may become available for other Turing-based cards like the GTX 1660 Ti, but currently, Optix requires the RT cores found in the RTX cards to use Optix. The GTX 1660, although it may have the Turing architecture, does not have the RT cores.
Optix is much faster than the Cuda backend in Blender, and Cuda was much faster than the OpenCL. However, now AMD users have a new option for GPU enhanced rendering, so that speed has been much improved. I don't know how much speed improvement Cycles X will offer to Cuda-based cards, but Lobo has suggested it is significant as well. Still, if you can get an Optix-enabled RTX card, you should see the greatest speed enhancements because of the extra RT cores.
My Free Models
My Video Tutorials
My CG Animations
I keep crossing my fingers that I can get an RTX card but between the bots that keep snatching them up not going to pay an over inflated price for one. Now for a another New tutorial feature of Blender 3.0 the Asset Browser which I look forward to exploring and learning more about
Lobo3433
Lobo, has Renderosity removed our ability to embed videos directly in the forum threads? I tried to embed a video in a reply the other day and it didn't work the way it had always done before.
My Free Models
My Video Tutorials
My CG Animations
I have had hit or miss with it if you see your buttons above when your writing a thread the last one is suppose to take you into HTML mode we did away with the markup a couple of months back as far as I know should be able to embed video using the HTML mode but like I said it has been hit or miss for me so I do not know if they have taken that feature away I will try to find out when I go into Slack tomorrow and ask in there.Lobo, has Renderosity removed our ability to embed videos directly in the forum threads? I tried to embed a video in a reply the other day and it didn't work the way it had always done before.
Lobo3433
Lobo3433 posted at 9:30 PM Sun, 5 December 2021 - #4431317
LuxXeon posted at 9:16 PM Sun, 5 December 2021 - #4431314Interesting. I don't see the HTML mode in my buttons anymore either. This is how my button panel looks now.I have had hit or miss with it if you see your buttons above when your writing a thread the last one is suppose to take you into HTML mode we did away with the markup a couple of months back as far as I know should be able to embed video using the HTML mode but like I said it has been hit or miss for me so I do not know if they have taken that feature away I will try to find out when I go into Slack tomorrow and ask in there.Lobo, has Renderosity removed our ability to embed videos directly in the forum threads? I tried to embed a video in a reply the other day and it didn't work the way it had always done before.
Whenever I try to add the embedded iframe code from Youtube, the post simply returns the code in code form instead of embedding the player. Here's an example:
<iframe width="560" height="315" src="https://www.youtube.com/embed/7wKnPclzYY8" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Sorry for interrupting the thread, BTW. If you want to delete this conversation and just contact me in private, its' ok. Thanks.
My Free Models
My Video Tutorials
My CG Animations
Seems you do not have the option the last button on my row is for HTML I already posted the question in Slack but I will not get a response till sometime tomorrow when I log in which I usually do sometime after noon
Lobo3433
Thanks for the Optix info Lux. I was aware I'll have to up date my driver to 470. I think right now it's 466.13, or something like that. Since this is a laptop, I'm not going to be looking for an RTX card. I purposely got the GTX 1660 Ti because Poser 11 didn't handle the RTX Turing series. I didn't, however, know the GTX 1660 Ti was also running on Turing, so I had to wait until the Poser dev team got it working with both the very new (2 years ago) Turing system cards.Optix requires a GPU with compute capability 5.0 and higher, and a driver version of at least 470, according to the Blender specs. Optix is currently ONLY supported by the RTX cards in Blender. There is speculation it may become available for other Turing-based cards like the GTX 1660 Ti, but currently, Optix requires the RT cores found in the RTX cards to use Optix. The GTX 1660, although it may have the Turing architecture, does not have the RT cores.
_______________
I think it's always important to include Andrew's ubiquitous doughnut tutorial, updated for Blender 3.0. It's basically the same tutorial it's always been, except now he includes some features specific to 3.0, such as Geometry Nodes for the sprinkles.
My Free Models
My Video Tutorials
My CG Animations
Yes, I noticed that recently while looking at his YouTube videos. I've always liked working with his tutorials, and have quite a few bookmarked.
_______________
Like LuxXeon posted above "Optix requires a GPU with compute capability 5.0 and higher, and a driver version of at least 470, according to the Blender specs. Optix is currently ONLY supported by the RTX cards in Blender. There is speculation it may become available for other Turing-based cards like the GTX 1660 Ti, but currently, Optix requires the RT cores found in the RTX cards to use Optix. The GTX 1660, although it may have the Turing architecture, does not have the RT cores." I have GTX 980Ti also and regretfully Optix is not supported by the card but you can still run Blender 3.0 with the this cardI have two 980TI 6GB cards,do you guys think that will run Optix
Lobo3433
In the spirit of the holidays came across this cute full tutorial that prehaps someone might want to try
Free Mini-Course for Blender 3.0 | Cute Character!
Lobo3433
No worries I have been known to miss some myself so all is goodLobo3433; sorry I guess I missed that post.
Lobo3433
New tutorials some might find of interest using Geometry Nodes in Blender
Generating Wings Procedurally with Geometry Nodes in Blender
by Arti Sergeev
https://80.lv/articles/generating-wings-procedurally-with-geometry-nodes-in-blender/
Lobo3433
Found this interesting way to use Animations & Geometry Nodes
Zombie Horde in Blender - Animations & Geometry Nodes
Lobo3433
Here is a quick tutorial on using Wireframe modifier to make a Greenhouse rather easily in Blender
How to use Wireframe Modifier in Blender - Greenhouse - Architecture Building 3D Modeling
Lobo3433
Ohhhh, now that looks very interesting Lobo, so thanks for posting it.
_______________
Yes I thought it was really interesting and very simple actually and your welcome I need to find some more recent ones to shareOhhhh, now that looks very interesting Lobo, so thanks for posting it. :slight_smile:
Lobo3433
Your welcome look forward to seeing some version posted to the GalleryOhhhh, now that looks very interesting Lobo, so thanks for posting it.
Lobo3433
For all those who have just joining or following our community here and looking for a good beginners series on Blender Youtube creator Zerobio is starting a new beginners series and I would high recommend watching and following along.
Lobo3433
Cycles X has become truly remarkable for both Nvidia and AMD GPUs. It particularly excels with Optix-enabled cards (RTX), but significant improvements have also been made for CUDA. Furthermore, there's a notable effort towards supporting AMD cards, including HIP framework support for RDNA architecture and Radeon Pro drivers. This represents a significant advancement in GPU rendering capability within Blender.
Thought it was about time to start a specific Blender 3.0 thread since this is the next Major version Update with many new tools and many improvements This being the case came across this tutorial that 1. I was not fully aware these auto retopology features were actually in Blender but how relatively easy they are to use in the video review 2 are built into Blender on is an external free program and one paid add-on I am sure each of you will take what is will work best in your own work flow.
The ULTIMATE Automatic Retopology Guide for Blender! by Russell Midfield
Lobo3433
Renderosity Store
My Free Stuff
Facebook
Twitter
