Tue, Nov 19, 10:58 PM CST
Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Nov 13 12:50 am)
Subject: The Poser Subdivision Morph Sorcery Project
odf ( ) posted Thu, 13 January 2022 at 12:55 AM · edited Thu, 13 January 2022 at 12:57 AM
Daily update: I appear to have successfully implanted the script into Poser. Grabbing the correct mesh data from the API (as in, matching what Poser would produce in unwelded/welded OBJ exports) proved more tricky than expected, but I got that working literally fifteen minutes ago.
Tests and cleanups to be scheduled for tomorrow. Also I'll see if I can get profiling to work from inside Poser so that I have a better idea of which parts take how much time. The general impression though is that the script is not significantly slower than the command line version.
ETA: Probably time to move to the Poser Python forum soon, since from here on I suspect it'll be mostly about GUIs and APIs.
odf ( ) posted Fri, 14 January 2022 at 12:44 AM
Okay, I think I've got a script that's streamlined enough to unleash onto a courageous few beta testers - a.k.a. whoever still follows this thread.
Get the code as a ZIP file from here or for git users, clone from https://github.com/odf/pydeltamesh.git.
Vague instructions:
A) Exporting the unmorphed mesh:
In Poser, load the figure, set to unimesh and the desired subdivision level, then export as OBJ with "As Morph Target" checked (sorry, no post-transform support at this point).
B) Making the morph:
In your favorite tool, import the OBJ from A), sculpt it to your heart's desire and export as OBJ again. Important: make sure to keep the vertex order and also (for now) the disconnected vertices intact.
C) Loading the morph:
Back in Poser, load the figure with the same settings as when exporting and make sure it's selected, then start the script via "Run Python Script" in the file menu. The path to use for the script is pydeltamesh/poser/loadSubdMorph.py within the unzipped folder.
The script asks for a name to give to the morph (if none given, the OBJ file name is used) and then pops up a file selection box where you can pick the OBJ created in B). After that, my Poser just seems to sit there for a few seconds before even showing a progress spinner, but eventually you should see a text box pop up with some diagnostics, and a dial for the new morph should appear.
-- End of vague instructions --
That's it for now. Undoubtedly there will be many bugs, so please be gentle with me.
primorge ( ) posted Fri, 14 January 2022 at 7:18 AM · edited Fri, 14 January 2022 at 7:20 AM
The unwelded bit is a no go.
Will this work with a prop version of the figure, subdivided, in scene? That is, in order to skip the unwelding bit. Transferring the working fbm from the prop to the figure, or even cleaning up any local empties, is trivial.
primorge ( ) posted Fri, 14 January 2022 at 7:22 AM
Pre emptive. Python3?
primorge ( ) posted Fri, 14 January 2022 at 7:36 AM
Actually, I have more questions. It'll have to wait til I'm done work this evening.
odf ( ) posted Fri, 14 January 2022 at 9:13 AM · edited Fri, 14 January 2022 at 9:19 AM
primorge posted at 7:18 AM Fri, 14 January 2022 - #4433229
Which unwelded bit are you referring to? There is no part of what I described that requires or would work with an unwelded mesh.
If you are interpreting “disconnected vertices” as unwelded, my apologies. I mean that Poser exports a mesh with some vertices that are not in any faces, and you need to leave those in. Blender does that with “keep vertex order,” if it is a problem with other software, I can fix that.
odf ( ) posted Fri, 14 January 2022 at 9:22 AM
primorge posted at 7:22 AM Fri, 14 January 2022 - #4433230
I’ve tested with Python2 as far as I could, but I can’t test with Poser 11 because I don’t own that. My hope is that if anything breaks in P11, there will be a useful stack trace.
primorge ( ) posted Fri, 14 January 2022 at 9:44 AM
I see, isolated vertices. I'll test in 11 via mudbox when I get home. Thanks for the clarification.
adp001 ( ) posted Fri, 14 January 2022 at 11:54 AM
Loaded LaFemme Pro "out of the box" (no morphs). Saved it as ob-file with subD 2.(Slowwww.....).
Loaded the object into Blender. Made some changes and exported to another file.
Started your script: loadSubdMorph. Got an error message, because Python 2.7 doesn't know "Process time". Changed that to "time" and restarted. After a long while I got this with an error at the end:
Loading mesh from \\VBOXSVR\Poser\Poser\Python\Rendo\pydeltamesh\Data\untitled_blender.obj...
Loaded mesh with 387296 vertices and 383752 faces.
Subdividing for baking...
Subdivided 3 times.
Finding deltas for level 0
Found a total of 11565 deltas for 83 actors.
Subdividing morph for level 1...
Subdivided 2 times.
Computing vertex normals...
\\VBOXSVR\Poser\Poser\Python\Rendo\pydeltamesh\makeSubdivisionMorph.py:294: RuntimeWarning: invalid value encountered in divide
  return ns / ds
Finding deltas for level 1...
Found 2884 deltas.
Subdividing morph for level 2...
Subdivided 1 times.
Finding deltas for level 2...
Found 10077 deltas.
Subdividing morph for level 3...
Finding deltas for level 3...
Traceback (most recent call last):
  File "\\VBOXSVR\Poser\Poser\Python\Rendo\pydeltamesh\poser\loadSubdMorph.py", line 66, in <module>
    loadSubdMorph(name, path)
  File "\\VBOXSVR\Poser\Poser\Python\Rendo\pydeltamesh\poser\loadSubdMorph.py", line 27, in loadSubdMorph
    targets = makeTargets(name, unwelded, welded, morph, used, verbose=True)
  File "\\VBOXSVR\Poser\Poser\Python\Rendo\pydeltamesh\makeSubdivisionMorph.py", line 94, in makeTargets
    name, weldedMorphed, morph, complexes, verbose
  File "\\VBOXSVR\Poser\Poser\Python\Rendo\pydeltamesh\makeSubdivisionMorph.py", line 254, in makeSubdTarget
    deltas, displacements = findSubdDeltas(verts, morphedVerts, normals)
  File "\\VBOXSVR\Poser\Poser\Python\Rendo\pydeltamesh\makeSubdivisionMorph.py", line 269, in findSubdDeltas
    diffs = morphedVertices[: len(baseVertices)] - baseVertices
ValueError: operands could not be broadcast together with shapes (387296,3) (1539199,3)
adp001 ( ) posted Fri, 14 January 2022 at 12:07 PM
Tried another time to make sure I had anything correct. This time with subD 1: similar output, same error at the end.
odf ( ) posted Fri, 14 January 2022 at 1:07 PM
primorge posted at 9:44 AM Fri, 14 January 2022 - #4433238
Isolated! Much better word!
odf ( ) posted Fri, 14 January 2022 at 1:10 PM
adp001 posted at 12:07 PM Fri, 14 January 2022 - #4433242
Thanks! Weird error! I’ll see if I can reproduce it somehow with what I have.
adp001 ( ) posted Fri, 14 January 2022 at 1:46 PM
Smells like a numpy error :)
I found this hint:
This error occurs when you attempt to perform matrix multiplication using a multiplication sign (*) in Python instead of the numpy.dot() function.
adp001 ( ) posted Fri, 14 January 2022 at 1:49 PM
https://stackoverflow.com/questions/24560298/python-numpy-valueerror-operands-could-not-be-broadcast-together-with-shapes
odf ( ) posted Fri, 14 January 2022 at 2:54 PM · edited Fri, 14 January 2022 at 2:57 PM
adp001 posted at 1:46 PM Fri, 14 January 2022 - #4433255
I found this hint:
It's certainly numpy that's complaining, but the problem is with the inputs, namely here that the morphedVertices array does not have enough rows (i.e. vertices). So the actual error would have happened earlier, possibly in a different numpy operation, but it could also be something else.
My hope is that I made a last minute change that I forgot to check for Python 2.7 safety, because that would be easy to reproduce and debug. If it's a P11 versus P12 thing, things will be trickier.
PS: By "weird error" I didn't mean that I was unfamiliar with this kind of error message. I'm very familiar, it's basically numpy's way of saying hello. I meant it's weird specifically that this kind of error happened on that line.
odf ( ) posted Fri, 14 January 2022 at 3:07 PM
Oops, I just noticed: you used LaFemme at subD 2 but my script subdivided the subD 0 mesh it grabbed from Poser three times. That hints at either a mismatch between the two meshes or some edge case in the subdivision algorithm that I haven't covered. If it's something about LaFemme's mesh (and assuming the Pro version, which I don't have, doesn't use a modified mesh), I should see the same problem appear in P12.
I'll have a go at this after breakfast.
odf ( ) posted Fri, 14 January 2022 at 4:28 PM
So, I've tried it with LaFemme. Works in Poser 12, works in Python 2.7 on the command line. But I'm getting different numbers for the mesh:
    Loaded mesh with 386835 vertices and 383504 faces.
Whereas you had:
So I'm still not sure if that's a P11 versus P12 thing, or LaFemme versus LaFemme Pro. It might be interesting to try a different figure. And it's probably useful if I add some more diagnostics and make the script bail out right away if the face counts don't match.
adp001 ( ) posted Fri, 14 January 2022 at 4:30 PM
With a loaded LaFemme:
fig=sc.CurrentFigure()
[ac.Name() for ac in fig.Actors() if not ac.IsBodyPart()]
[u'CenterOfMass', u'GoalCenterOfMass', u'rThumb0Con', u'rIndex0Con', u'rMid0Con', u'rPinky0Con', u'rRing0Con', u'lThumb0Con', u'lIndex0Con', u'lMid0Con', u'lRing0Con', u'lPinky0Con', u'UpperBrowCon', u'RightOuterBrowCon', u'LeftOuterBrowCon', u'MidBrowCon', u'RightInnerBrowCon', u'LeftInnerBrowCon', u'RightUpperEyeLidCon', u'LeftUpperEyeLidCon', u'RightLowerEyeLidCon', u'RightUpperCheekCon', u'LeftUpperCheekCon', u'RightLowerCheekCon', u'LeftLowerCheekCon', u'NoseCon', u'RightNostrilCon', u'LeftNostrilCon', u'UpperLipCon', u'RightUpperLipCon', u'RightLipCon', u'LeftUpperLipCon', u'LeftLipCon', u'RightEarCon', u'RightEarLobeCon', u'LeftEarLobeCon', u'LeftEarCon', u'LeftLowerEyeLidCon', u'RightBreastCon', u'LeftBreastCon', u'RightGluteCon', u'LeftGluteCon', u'LowerLipCon 1', u'RightLowerLipCon 1', u'LeftLowerLipCon 1', u'JawCon', u'RightLabiaCon', u'LeftLabiaCon', u'MonsPubisCon']
All this actor are not bodyparts. But they will be exported and interfere a lot when sculping in Blender.
adp001 ( ) posted Fri, 14 January 2022 at 4:32 PM
odf posted at 4:28 PM Fri, 14 January 2022 - #4433264
Whereas you had:
LaFemme Pro shouldn't make a difference.
I tried with Bella too. Same errors.
adp001 ( ) posted Fri, 14 January 2022 at 4:39 PM
I definitely set SubD 2 (also for Bella), and your script tells something about "Subdividing morph for level 3".
odf ( ) posted Fri, 14 January 2022 at 4:58 PM
adp001 posted at 4:30 PM Fri, 14 January 2022 - #4433265
Do any of these have geometry? I tried to export some from P12 and got empty files. Maybe P11 handles them differently.
odf ( ) posted Fri, 14 January 2022 at 5:01 PM
adp001 posted at 4:39 PM Fri, 14 January 2022 - #4433268
At the moment, the script keeps subdividing the base level mesh as long as it has fewer faces than the mesh that was loaded in from file. So if the latter has extra polys that shouldn't be there, an additional subdivision level will result. That's obviously not a very robust strategy, so I'll change it and throw an exception instead.
odf ( ) posted Fri, 14 January 2022 at 5:10 PM
If exporting a clean mesh is a problem, I would certainly be open to using a custom exporter. I haven't had that problem in P12 yet, so I'm a bit confused at what is going on with P11 there.
adp001 ( ) posted Fri, 14 January 2022 at 5:17 PM
odf posted at 4:58 PM Fri, 14 January 2022 - #4433270
ac=fig.Actor("CenterOfMass")
ac.Geometry().NumVertices()
324
ac.Geometry().NumPolygons()
360
odf ( ) posted Fri, 14 January 2022 at 5:18 PM
Hmm, it looks as if my P12 registration number lets me download P11, so I'm doing that now and will see if I can also install and run it. That should be much easier for testing.
adp001 ( ) posted Fri, 14 January 2022 at 5:37 PM
Hold on - seems I had a problem. Testing...
adp001 ( ) posted Fri, 14 January 2022 at 5:45 PM
I'm soooo sorry! All good! Works!
Subdivided 2 times.
Found a total of 24478 deltas for 83 actors.
Subdivided 1 times.
Found 3193 deltas.
Found 9408 deltas.
Morph loaded in 23.4530000687 seconds.
Problem was here. I changed Blender from 2.9 to 3. But had not yet adjusted my preferences.
adp001 ( ) posted Fri, 14 January 2022 at 5:51 PM
I'm off to bed. Looks like I caught a cold.
Congrats, by the way! Nice work.
odf ( ) posted Fri, 14 January 2022 at 5:53 PM
adp001 posted at 5:45 PM Fri, 14 January 2022 - #4433278
Phew! Such a relief! 👍
odf ( ) posted Fri, 14 January 2022 at 6:14 PM
I've now also pushed the change from time.process_time() to time.time() that was necessary to make Python 2.7 happy.
Silly mistake of me to use process_time(), seeing as I looked it up in the docs which clearly state that it's a Python 3 feature.
primorge ( ) posted Fri, 14 January 2022 at 9:39 PM · edited Fri, 14 January 2022 at 9:39 PM
Threw an error from 11 to Mubox. Figure is Nova with 2 levels subdivision. Might be a Mudbox thing though, honestly I don't think I've ever morphed in Mudbox without using the PML exporter. I've been using it so long that my memory is vague on that. I'll have to test that particular with a regular FBM without PML exporter. In any case I'll test via Blender 2.92 and report back. Here's the test morph imported into Poser from Mudbox as a prop. Here's the Python Error message.
I do have one question however, you didn't mention whether 'Include Existing Groups in Polygon Groups' was requirement during initial export. In this instance all I checked was 'as Morph Target' as you stated in your instructions...
primorge ( ) posted Fri, 14 January 2022 at 10:13 PM
Tested FBM from Mudbox via both unwelded scene export ang geometries import. Without PML the FBMs do not translate working into Poser. Looks like the groups are borked. Single actor morph targets work fine however, no wrong # verts error or winding order explosions.
So for Mudbox it's very likely not your scripts fault. Looks like PML will stay my method for morphing with MB.
For my usage, bear in mind I have Zbrush, this will be useful for Blender SubD morphs only. Going to test Blender now...
odf ( ) posted Fri, 14 January 2022 at 10:23 PM
primorge posted at 9:39 PM Fri, 14 January 2022 - #4433284
That looks like Mudbox might be removing isolated vertices. If I'm right, the second (larger) number in the error message should be the vertex count of the mesh exported from Poser, and the first (smaller) one should be what comes out of Mudbox. Also, both meshes should have the same number of polygons.
The requirement that the isolated vertices must be preserved is a relic from my original command line script. Within Poser I can easily add code that fixes the numbering for that specific case. Unless you're very eager to get the Mudbox test working, I might defer that until after I've finished the post-transform option (i.e. probably tomorrow).
No, that's not a requirement, unless you want access to the group info in your modeler. My script doesn't use the groups.
odf ( ) posted Fri, 14 January 2022 at 10:31 PM
primorge posted at 10:13 PM Fri, 14 January 2022 - #4433288
We shouldn't give up on Mudbox that quickly. Unless PML does something unconceivably clever, if it can deal with your MB outputs, my script should be able to, too, possibly after some small adjustments.
odf ( ) posted Fri, 14 January 2022 at 10:37 PM
I love how she still looks unmistakably like Nova in that morph.
primorge ( ) posted Fri, 14 January 2022 at 10:58 PM · edited Fri, 14 January 2022 at 10:58 PM
Tried same with Blender. Received a different error this time. Error screencap, morph prop screencap...
Yes, she's still recognizable. It's the nose and the lips, I didn't morph them at all for these tests.
Anyway. Not having much luck... not blaming your script either. Could be so many things. I did follow the instructions however. I'll try again later. Sorry I couldn't help.
odf ( ) posted Fri, 14 January 2022 at 11:34 PM
primorge posted at 10:58 PM Fri, 14 January 2022 - #4433295
Not at all! That's very helpful. Sorry about the frustrating experience so far, but every error message makes the script a little better.
odf ( ) posted Sat, 15 January 2022 at 12:57 AM
End-of-day update: post/pre transform morphs both seem to be working now, and I have two improvements to OBJ loading on my list for tomorrow.
primorge: I think your Blender exports should work if you export with normals and/or UVs, but that would be silly as a restriction, seeing as the script does not use either. Easy to fix, though!
odf ( ) posted Sat, 15 January 2022 at 5:53 PM · edited Sat, 15 January 2022 at 5:55 PM
So, a new version is up at the same location with the following three changes:
1) There is now an additional dialog that lets one choose between creating a pre- or a post-transform morph.
2) The OBJ file for the morph can now contain "f" lines without slashes, so e.g. Blender exports with neither normals nor UVs should now work. That fixes an oversight of mine that tripped up primorge's Blender test.
3) The input mesh is no longer required to have isolated vertices preserved from the original Poser export. Of course the order of the remaining (non-isolated) vertices still needs to be kept intact. This might fix the problem with the Mudbox export, but without looking at the actual OBJ files that is of course just a guess.
Hopefully this version will prove more successful.
odf ( ) posted Sat, 15 January 2022 at 8:17 PM · edited Sat, 15 January 2022 at 8:19 PM
Also, I might take a break from this project for a bit, apart from bug fixes and urgent feature requests. I'm pretty happy with how it turned out so far, and it's probably best to let real usage experience drive further developments.
Maybe I'll spend a few days with just sculpting and/or clothes making practice...
primorge ( ) posted Sat, 15 January 2022 at 10:01 PM · edited Sat, 15 January 2022 at 10:03 PM
odf posted at 5:53 PM Sat, 15 January 2022 - #4433335
Sounds great. I've gone down a rabbithole with painting eye maps so haven't had time to test further, but I have off tomorrow so I'll take a break from texturing and give the new version a spin, the additional tweaks sound great... crossing fingers. If the mudbox export throws an error I'll save the example obj for you to look at via PM link.
Thanks for all your hard work on this.
odf ( ) posted Sat, 15 January 2022 at 11:12 PM
primorge posted at 10:01 PM Sat, 15 January 2022 - #4433341
That would be great. The original Poser export too, please.
Gladly! It's what I do for fun in these parts. 😄
odf ( ) posted Sun, 16 January 2022 at 5:47 PM
Micro-update: I just checked in an update that makes the logging messages show up right away instead of holding it back until the script has finished. I might add even more messages, just so that it's more apparent that the script is indeed still working.
primorge ( ) posted Mon, 17 January 2022 at 5:47 PM
Tried again, latest ver., with MB... got an invalid syntax error.
odf ( ) posted Mon, 17 January 2022 at 7:15 PM · edited Mon, 17 January 2022 at 7:20 PM
primorge posted at 5:47 PM Mon, 17 January 2022 - #4433421
Argh! I forgot that print is not function in Python 2. Sorry! If you feel adventurous, you can just change that line to "log = None" for now (don't change the line indentation, though).
The fixVertexOrder script will have the same problem. I'll have an updated download for both up shortly.
ETA: The fixed version is now up.
primorge ( ) posted Mon, 17 January 2022 at 7:52 PM · edited Mon, 17 January 2022 at 7:52 PM
Cool. Thanks odf...  needn't have rushed I'm in the middle of setting up a pose for later use :D... I'll save and test asap.
Thanks again for the timely support... starting to feel like a nag lol.
odf ( ) posted Mon, 17 January 2022 at 8:17 PM
primorge posted at 7:52 PM Mon, 17 January 2022 - #4433430
It's not like my efforts at learning MD are particularly time-critical. My response times will increase significantly when I'm back at my day job.
primorge ( ) posted Mon, 17 January 2022 at 8:28 PM · edited Mon, 17 January 2022 at 8:28 PM
Bad news. Got this error from both MB and Blender exports...
primorge ( ) posted Mon, 17 January 2022 at 8:31 PM
Antonia 1.2 was the subject this time...
primorge ( ) posted Mon, 17 January 2022 at 8:35 PM
I'm curious if anyone else besides me, ADP, and yourself has tested this... With over a thousand views surely someone else can report something, no?
