Thu, Dec 12, 11:31 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 12 3:30 am)
Subject: Poser shortcut file location
Uncanny_Film ( ) posted Fri, 25 March 2022 at 3:53 PM · edited Thu, 12 December 2024 at 9:47 AM
Hello, can anybody help me locate the Keyboard shortcut file that poser saves.
I want to take a look at it because of a device I'm trying to create.
Thanks
Win10 - AMD 2nd Gen Ryzen Threadripper 2950X, 16-Core, 32 Thread 4.4 GHz - 128GB Ram - X2 GeForce RTX 3060 Ti - 3D-connexion
Poser 12 | Octane Render |  Real-Flow | 3DCoat | Speed Tree | Adobe Premiere  |  Adobe After Effects |  Adobe Audition |  Adobe Photoshop
Y-Phil ( ) posted Sat, 26 March 2022 at 12:01 PM
You should taker a look at a file named "Poser.xrc". For Poser11 as well as for Poser12: it's installed in a subfolder called "ui", under "runtime", but the "runtime" folder where your executable is lying.
The file in question looks like an XML one.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Mac Mini M2, Sonoma 14.6.1, 16GB, 500GB SSD
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
Uncanny_Film ( ) posted Tue, 29 March 2022 at 10:33 AM
Y-Phil posted at 12:01 PM Sat, 26 March 2022 - #4436398
Thanks for pointing me in the right direction. But I cannot seem to find the shortcuts for the scripts. When I create a custom shortcut for a script I want to know it's saved location.
Y-Phil ( ) posted Tue, 29 March 2022 at 12:54 PM
spartan00j posted at 10:33 AM Tue, 29 March 2022 - #4436544
It's true that the official Poser documentation is somewhat... succinct  to say the least...
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
Uncanny_Film ( ) posted Fri, 20 May 2022 at 2:41 PM
Y-Phil posted at 12:54 PM Tue, 29 March 2022 - #4436548
So basically I'm out of luck?  🥺
Y-Phil ( ) posted Sat, 21 May 2022 at 8:28 AM · edited Sat, 21 May 2022 at 8:30 AM
spartan00j posted at 2:41 PM Fri, 20 May 2022 - #4438874
I tried to add a shortcut to select the Aux Camera and the file that got changed is Accelerators.xml.
It's located in Poser's profile, which means %appdata%\Poser\12  or %appdata%\Poser Pro\11 on Windows platforms and depending on your Poser verson.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
DCArt ( ) posted Sat, 21 May 2022 at 12:45 PM
It's not an oversight in the documentation. There are no default script shortcuts in Poser (at least, there are none listed in the Keyboard Shortcuts list) which is why the category is blank in the manual.  Each developer will no doubt use their own script shortcuts in each script they create, so unfortunately there is no easy way to track them all.
To see a list of all keyboard shortcuts used in Poser, choose Edit > General Preferences (or use Ctrl+E). Then select the Interface tab, and click the Edit Shortcuts button in the lower right of the General Preferences dialog. You can use that dialog to add script shortcuts that you need.
DCArt ( ) posted Sat, 21 May 2022 at 1:02 PM
I've pinged for someone on the team to take a look at this thread, in case there is a preferred location for customized shortcuts
nerd ( ) posted Sat, 21 May 2022 at 8:11 PM · edited Sat, 21 May 2022 at 8:12 PM
Forum Moderator
The user shortcuts are stored in %appdata%\Roaming\Poser\12\Accelerators.xml
If no user shortcuts have been created that file may not exist and it will only contain the shortcuts a user has created.
