Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 19 3:46 am)
You should taker a look at a file named "Poser.xrc". For Poser11 as well as for Poser12: it's installed in a subfolder called "ui", under "runtime", but the "runtime" folder where your executable is lying.
The file in question looks like an XML one.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Win11 on i9-13900K@5GHz, 64GB, RoG Strix B760F Gamng, Asus Tuf Gaming RTX 4070 OC Edition, 1 TB SSD, 6+4+8TB HD
👿 Mac Mini M2, 16GB, 500GB SSD
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
Win10 - AMD 2nd Gen Ryzen Threadripper 2950X, 16-Core, 32 Thread 4.4 GHz - 128GB Ram - X2 GeForce RTX 3060 Ti - 3D-connexion
Poser 12 | Octane Render | Real-Flow | 3DCoat | Speed Tree | Adobe Premiere | Adobe After Effects | Adobe Audition | Adobe Photoshop
spartan00j posted at 10:33 AM Tue, 29 March 2022 - #4436544
Y-Phil posted at 12:01 PM Sat, 26 March 2022 - #4436398It's true that the official Poser documentation is somewhat... succinct to say the least...You should taker a look at a file named "Poser.xrc". For Poser11 as well as for Poser12: it's installed in a subfolder called "ui", under "runtime", but the "runtime" folder where your executable is lying.
Thanks for pointing me in the right direction. But I cannot seem to find the shortcuts for the scripts. When I create a custom shortcut for a script I want to know it's saved location.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
Y-Phil posted at 12:54 PM Tue, 29 March 2022 - #4436548
So basically I'm out of luck? 🥺spartan00j posted at 10:33 AM Tue, 29 March 2022 - #4436544
I tried to add a shortcut to select the Aux Camera and the file that got changed is Accelerators.xml.
It's located in Poser's profile, which means %appdata%\Poser\12 or %appdata%\Poser Pro\11 on Windows platforms and depending on your Poser verson.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
It's not an oversight in the documentation. There are no default script shortcuts in Poser (at least, there are none listed in the Keyboard Shortcuts list) which is why the category is blank in the manual. Each developer will no doubt use their own script shortcuts in each script they create, so unfortunately there is no easy way to track them all.
To see a list of all keyboard shortcuts used in Poser, choose Edit > General Preferences (or use Ctrl+E). Then select the Interface tab, and click the Edit Shortcuts button in the lower right of the General Preferences dialog. You can use that dialog to add script shortcuts that you need.
Hello, can anybody help me locate the Keyboard shortcut file that poser saves.
I want to take a look at it because of a device I'm trying to create.
Thanks
