Wed, Feb 5, 8:36 PM CST
Renderosity Forums / New Poser Users Help
Welcome to the New Poser Users Help Forum
New Poser Users Help F.A.Q (Last Updated: 2025 Feb 04 3:01 am)
Subject: Exporting from poser
Navim ( ) posted Fri, 03 June 2022 at 7:06 PM · edited Wed, 05 February 2025 at 6:43 PM
Does poser 12 export any better than P11? I just bought a tree model from Dinoraul only to find it was in poser format, Since I work in Bryce this means I will have to export the model and my success rate with the p11 vers. is approaching pathetic.
Thanks
Mike aka navim
RedPhantom ( ) posted Fri, 03 June 2022 at 9:08 PM · edited Fri, 03 June 2022 at 10:33 PM
Site Admin
I do believe the marketplace requires products to include obj files with all models. You might look in the geometry folder. What format are you exporting to? I've never had any trouble with obj from any version of poser.
Navim ( ) posted Fri, 03 June 2022 at 11:20 PM
RedPhantom posted at 9:08 PM Fri, 3 June 2022 - #4439538
I will check to see if an obj is available. Big problem i run into is bryce not asking for any texture file upon opening the obl, Wondering if this requires a reinstall of bryce?
Navim ( ) posted Fri, 03 June 2022 at 11:25 PM
Navim posted at 11:20 PM Fri, 3 June 2022 - #4439542
I checked the file and it is only poser content
RedPhantom ( ) posted Sat, 04 June 2022 at 7:15 AM
Site Admin
When you export the tree, check use full texture path in the export options pop up.
Navim ( ) posted Sat, 04 June 2022 at 10:32 AM
RedPhantom posted at 7:15 AM Sat, 4 June 2022 - #4439549
Good morning. I tried checking use ftp's as you suggested and the leaves show up as rectangles. I want to thank you for your help but this is just too much time to spend on a model when there are other sources for less expensive models that work. I am going to ask renderosity for a refund and will not purchase any more plants from this vendor
Regards,
NikKelly ( ) posted Sun, 05 June 2022 at 8:43 AM
Sounds like you have texture plus transparency mapped onto place-holder rectangles. Much, much lower-poly than drawing each leaf's near-fractal detail...
Please check for transparency map(s). If not stand-alone, may be texture's Alpha-channel in PNG, or equivalent in eg DDS.
Free 'Irfan View' is your graphics-format friend...
Navim ( ) posted Sun, 05 June 2022 at 10:55 AM
NikKelly posted at 8:43 AM Sun, 5 June 2022 - #4439564
Thank you, but I have already deleted the model file.
