Thu, Jan 30, 3:42 PM CST
Renderosity Forums / Poser 12
Welcome to the Poser 12 Forum
Poser 12 F.A.Q (Last Updated: 2025 Jan 26 3:18 pm)
Subject: About control the vertices of the model mesh
Tekitoumen ( ) posted Wed, 22 June 2022 at 3:11 AM · edited Thu, 30 January 2025 at 8:34 AM
Hi! I have a quesution.
I want to transform the model by changing the vertices of the mesh.
Not just the GUI, I want to transform the model by changing the vertices of the mesh.
Is it possible to control the coordinates of the model mesh with a python program?
If you know, please tell me.
Thank you.
FVerbaas ( ) posted Thu, 23 June 2022 at 1:04 PM · edited Thu, 23 June 2022 at 1:08 PM
Forum Coordinator
Yes a Python script can change the coordinates of a vertex.
Do not forget to force a redraw once you're done moving them, or there will be no visible effect. Also tag the object as 'changed'. Python bypasses all this.
Tekitoumen ( ) posted Wed, 29 June 2022 at 9:38 PM
Thank you!
Tekitoumen ( ) posted Thu, 30 June 2022 at 7:18 PM
Excuse me, do you know which method is used to change the coordinates of the vertices of the mesh?  Geometry Methods correct?
FVerbaas ( ) posted Sat, 02 July 2022 at 5:21 PM · edited Sat, 02 July 2022 at 5:27 PM
Forum Coordinator
Vertex methods.
From the top  of my head: mygeom.Vertices(i).SetX(newX,newY, newZ)
Remember coordinates are defined in PNU units for zero pose in world space.
There used to be a set of example scripts: geomods
Tekitoumen ( ) posted Sun, 03 July 2022 at 7:06 PM
I will try.
Thank you very much for your kindness!
