Forum Moderators: Lobo3433 Forum Coordinators: bwsupport
Blender F.A.Q (Last Updated: 2025 Feb 17 11:37 pm)
As of my current understanding the Daz to Blender bridge only currently supports Blender 2.9 and Blender 3.0 and above have made some changes in python that scripts or add-ons from prior to 3.0 are not operating as they should most add-on developers have fixed this but even the most current version of Daz's bridge still does not work with Blender 3.0 and above and since 3.2 is still recent release there are still some bugs in it. Maybe someone at either Daz Support or their forum may have come up with a work around. Sorry wish I could offer more help
Lobo3433
I agree with Lobo. Looks like a weight mapping issue on the fingers, probably caused by certain incompatibility between the python version of the addon and this version of Blender.
My Free Models
My Video Tutorials
My CG Animations
Instagram: @luxxeon3d
Facebook: https://www.facebook.com/luxxeon
Your welcome infinity10 I hope you find a solution and if you do please share it as it might help someone else with a similar issue
Lobo3433
I have not received any response from any of the support forums I have contacted. However, I continued pursuing the topic on my own, and found some leads.
There is a function called Preserve Volume in Blender's UI - but I cannot locate it as yet. Apparently that may be one way to prevent the morphs from distorting the mesh unnaturally.
Another possible route to investigate is to add a Vertex Group to the distorting parts (in my case, the hands) . See this: https://blender.stackexchange.com/questions/249993/preserve-volume-vertex-group I have not attempted this solution yet, but it seems plausible as a solution.
Eternal Hobbyist
OK doing a quick search for the Preserve Volume in Blender is this link from the Blender Manual https://docs.blender.org/manual/en/latest/modeling/modifiers/deform/armature.html Seems you find the option in the modifier stack under the Modifier Stack for the Armature also I noticed you are using a Blender version that looks like a custom build have you tried using just default Blender version there might actually be conflicting mods with in that build you are using that might be the root cause of the issue you are running into.
Lobo3433
Problem is resolved. I had tried to transfer the figure with an animation applied to it. Developers responded to me with a checklist and the one item I had not done was to set the figure in zero pose before transferring via the bridge. So I do not have to fix anything inside Blender. Here are my attempts at sending over a fresh figure without animation and in zero pose. Character is still applied inside Blender. No hand distortions.
Eternal Hobbyist
Great I am glad you found a solution I am sure others will find this information useful :thumbsup:
Lobo3433
Just an update there has been a new release update to the Daz to Blender bridge that now support upto current versions of Blender
Lobo3433
I used the Daz2Blender Bridge to import a commercial character of the Genesis 8 Male into Blender3D version 3.2 (nVidia Omniverse flavour).
I get these distorted hands when the file is transferred.
I know that if the problem occured inside Daz Studio, the fix is to Adjust Rigging To Shape inside DS.
However, the problem exists inside Blender3D, not DS. Inside DS, the morph character is fine.
Is there a setting inside Blender3D that I can use to fix the distorted hands ? Please advise me, thanks.
( I have contacted Daz3D Tech Support but they tell me they don't deal with the Bridge matters, and that I should contact the bridge programmers directly, but I have not done so yet, because I don't think it is a Bridge problem, but a rig-related setting.)
Eternal Hobbyist
