Sun, Jan 5, 9:46 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2025 Jan 04 8:20 pm)
Carrara Free Stuff here.
Subject: Spline vs vertex
benney ( ) posted Mon, 18 July 2022 at 5:08 AM · edited Thu, 12 December 2024 at 7:12 AM
This may sound a little silly but i have always wondered which modeller takes up the most memory, the Spline or Vertex modeller?
ProPose001 ( ) posted Tue, 19 July 2022 at 3:48 AM
Couldn't tell you.  The only time I've used the Spline modeler  is when I open some of the default native content,  which I immediately convert to a Vertex object.  I've tried using the Spline Modeler, but I'm also missing a lot of hair now.
benney ( ) posted Wed, 20 July 2022 at 4:50 AM
I also tend to use the vertex modeller or Hexagon for the more complicated models. But there are so many ways you could literally cheat by using the spline modeller. I am just wondering if it would be worthwhile using that option on some models without pushing the CPU... and i know what you mean about the hair situation, why do you think I shave my head these days LOL
WendyLuvsCatz ( ) posted Sat, 23 July 2022 at 5:30 PM
it definitely is lighter on resources to use the spline modeller unless you use the Octane render plugin, then it's not as smooth as it becomes vertex mesh, same with metaballs.
I can only make simple spline models like bottles, bowls, glassware etc and they definitely are nicer than vertex lathed ones, I wish I knew how to do more, I can do spirals,  coils and springs and bathtubs
Dreaming Kitty Channel
Tom R. Toe
My ArtyFarty AI channel
benney ( ) posted Sat, 30 July 2022 at 5:35 AM
Thanks for the info. It certainly helps me. The project I am planning will take some very complicated vertex work but a lot of of simpler shapes that i know the spline can handle. So combining the two trying is the plan to save the CPU count.
Again, thanks for the information.
