Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 15 2:13 am)
I won't make this one available. I will do one that won't be taxing to most computers. This one was just an exercise to come up with a way to model it. Turns out a torus and a cylinder are the only things I needed.
The final product will be available. And have a few more details, like an activation button or switch. This one was based off a 3D printed version. I will try to find some better reference images later on.
The way it's supposed to work is that the emitter heads are attached to the ring, and they spin around it when it's ignited. But I can't find a decent picture of one to be able to emulate that. I am going to have to wing it. All the reference images I find are not really good enough to figure out how it works.
I can take a crack at retopoing it for you. Strictly algorithm in either mudbox or Zbrush. I have retopoflow for Blender but thats very time consuming, its manual retopology. Very cool but still some work. I find it meditative though. I use it a bit for making clothes ( what little I've made) or fixing some of my basemeshes that I hoard. The results with algorithm retopology aren't "wow beautiful craftsmanship" but more like "hey it's the forms in less than a million polys at a button push and a few edgeflow guide strokes"
I realized where I went wrong. Since I didn't get too far along, I am simply going to delete the cylinder and start again.
But thanks for the offer. I was off taking care of my pit bull and got notified of a response. I don't hang out here like I used to. I don't think anyone does, judging by how slow some of these threads are.
I just didn't know how to get into the mix. I wasn't offended or shocked...rokket posted at 10:23 PM Sat, 13 August 2022 - #4442745
The horror. How about "screw you primorge" lol. I won't break.Wow, I don't know how to respond...
Thanks again for helping me find that dress hborre :)
hborre posted at 7:56 PM Tue, 16 August 2022 - #4442829
Not exactly. You will see once the render is done. It's at 72 of 256 samples. I want it to run a little bit longer to clean it up. I used BB's IBL setting for the lighting, and some walls and those mirrors I mentioned.Was that allowing herself to be pushed off the building by the Green Goblin?
There is some comedy in this....
hborre posted at 8:26 PM Tue, 16 August 2022 - #4442832
She has gone by soooo many different names since she debuted.Ah, the Ghost Spider!
This render didn't cook long enough, but you get the idea. I will probably do another one when I am busy and can let it go the distance.
What type of lighting are you trying to achieve? By my assessment, since this is a studio you should have multiple light sources from the ceiling. Studio walls are painted in light colors, they are much more reflective and illuminate the room. And don't forget that overhead lamps need inverse squared attenuation to simulate realistic light dropoff.
I added 3 torus' and then lit them with the Physical Surface node by ramping up the emissions. I don't know how to change the attenuation. I will look. It's probably something I know but my old brain wants to forget.
I use progressive sampling, so that was the shot as soon as the scene popped up. It's almost 60% rendered right now. I am seeing some spots (what is the nickname for those?) in the render that may or may not render out. My pixel sampling is 12, and it has served me well. Maybe this one will need more, but I will wait and see.
So the fireflies were mostly in the mirrors. I guess I have to change the settings on the reflective surface in the materials room.
In the meantime, I have messed with this enough for today...
I didn't let the render finish. It was about 67% finished when I stopped it. I am pretty sure it wouldn't have looked much better if I let it go the distance, until I change a few settings here and there.
hborre posted at 7:59 PM Wed, 17 August 2022 - #4442882
Hahahaha!!!!!That hand will take time to heal properly. I guess no web-slinging for a while.
Worse, she swatted her on the ass, and the result was Jennifer trying to catch her to smack her too. The studio got torn apart...
If you set the u_offset to .25 on BB's EnvSphere, it will match the background's default rotation. Then you can turn the sphere to see what rotation you want. Then convert the y-rotation from degrees to radians and set that in the background's rotation if you use the setup here https://www.renderosity.com/forums/threads/2961030/rotation-when-using-an-hdr-bitmap-on-the-background-node. It sounds way more complicated than it is.
you can use the background to light an outdoor set and it will provide the sunlight and shadows. Background lighting also renders with less noise than a dome. I don't use background lighting all the time but it does make sense for outside shots.
I'm not sure anyone is even following this thread anymore, but anyhow...
I did a quick down and dirty Inquisitor Lightsaber. I didn't detail it much, and only put placeholder materials on it. I am going to do one that is not as poly heavy as this one is, at over 50K.
But what do you think? Can anyone use this? I will model the blades if anyone wants it.
