DAZ|Studio F.A.Q (Last Updated: 2024 Oct 21 9:46 pm)
SAMS3D posted at 4:17 PM Sat, 13 August 2022 - #4442730
oh nooo no no that is my very oldest stuff>.<Your gallery is amazing!
https://thereal-darkelegance.wixsite.com/darkelegance
newish stuff? not so old?
*makes note to change her sig on here*
https://www.darkelegance.co.uk/
Hello DE,
Congratulations on getting a new machine.
"SO I need advice:
1-absolutely the BEST render settings that will get photorealistic results? (both for architectural scenes and also settings for say figure scenes)
2-Best light set (general use) for DS
3-Best texture set for genesis 8? (both female and male)"
Having glanced at your old gallery, I see you like rendering darker scenes. Your scenes are similar to mine (low lighting). So I will share what I know to work best with darker renders based on my experience. I know you are asking for the best, I have used D S for about 5 yr now as a part time hobby, so I might not know the BEST stuff out there, but I hope what I share can get you started.
1. the render setting that I frequently use for my renders :
and
For crispier renders. don't use the denoiser. Change the pixel filter from default 1.5 to 1 or lower.
Set max samples to 5000 or higher. I set mine at 10000. set max time to 0
This may not be the BEST setting, but it should be enough to get rid of the fireflies in your dark renders. Ofcource, you can always stop the render when you feel that your render quality is to your satisfaction.
2. Lights... I can't give you any suggestions since I've never purchased any light set. Lighting is very subjective. Every scene requires a different set of light. There are so many variations and it's. I suggest you learn proper lighting by first understand each DS lighting tool. I watched WP Guru aka Jay Versluis youtube channel. and photographic lighting tutorials on youtube.
Lighting is 75% of the work you have to put into your scene, so there is no light sets out there that will give you a perfect scene all the time.
3. BEST shaders/textures. This is very subjective. I can only tell you what I've used and like. I haven't tested all the shaders out there. I will just suggest a few PA's that I've purchased from. For G8.1F,I've used ChangelingChick's RozalinaHD, and Mousso's Echo. For G8F, I've used Sangriart, Saiyaness, Mousso, Chevybabe25. For G8m, I've used Phoenix1966, and Mousso,
I haven't got anything 8.1 yet.
Most of these shaders are quite photo realistic with the right lighting
Side note: Don't get to hung up on photo realism. Don't give up aesthetics for the sake of realism. A well made cinematic movie is always prettier than a documentary imho.
Good Luck!
JV
Software: Daz Studio 4.15, Photoshop CC, Zbrush 2022, Blender 3.3, Silo 2.3, Filter Forge 4. Marvelous Designer 7
Hardware: self built Intel Core i7 8086K, 64GB RAM, RTX 3090 .
Thank you!! I finally have my NVIDIA and am looking forward to being able to get back into working again with DS.Hello DE,
"SO I need advice:
and
Set max samples to 5000 or higher. I set mine at 10000. set max time to 0This may not be the BEST setting, but it should be enough to get rid of the fireflies in your dark renders. Ofcource, you can always stop the render when you feel that your render quality is to your satisfaction.
Good Luck!
JV
Hello
So, I have gotten back into 3d. I broke down this time around, and purchased a spanking new puter. Lovely NVIDIA card,etc.
I hit render on the base settings of DS and blinked and it was done.
Needless to say I want to really get the render boat out there....but as its been roughly 6 years since I last worked with 3d full-time, I am abit out of the loop.
SO I need advice:
I have been making purchase from Daz to the lead up of the puter arriving and I do have some of the newer toys (wings by arki, a cyberpunk bike. etc)
But I need to make the best bang for my buck.
SO I come to pick your great minds ^_^
Commission Closed till 2025
