Sun, Nov 24, 10:38 PM CST
Renderosity Forums / Poser 12
Welcome to the Poser 12 Forum
Poser 12 F.A.Q (Last Updated: 2024 Oct 22 2:54 pm)
Subject: Poser 12 Renders
ironsoul ( ) posted Tue, 20 December 2022 at 12:32 PM
Thanks for the advice hborre and ghostships much appreciated, it is always fascinating trying to model how light works :)
ChromeStar ( ) posted Wed, 21 December 2022 at 3:31 PM · edited Wed, 21 December 2022 at 3:32 PM
ghostship2 posted at 6:56 PM Sun, 18 December 2022 - #4452071
Is it ok to make all three subsurface radius dimensions the same now? I thought there was a bug that resulted in no subsurface scattering if all three were equal.
hborre ( ) posted Wed, 21 December 2022 at 4:17 PM
This was found to be confirmed with the PhysicalSurface node.  I haven't seen this behavior on the PrincipledBdsf node, the primary driver of SSS is the Subsurface channel, the higher the value the more prominent the translucency.  Go too high and you will introduce firefly artifacts.
ghostship2 ( ) posted Fri, 23 December 2022 at 7:20 PM
I'm working on something that might look better than the mat I posted.
ghostship2 ( ) posted Fri, 23 December 2022 at 8:17 PM · edited Fri, 23 December 2022 at 8:17 PM
OK, what I got uses transmission instead of SSS. This cuts out the glowing effect but still gives some depth to the ivory and keeps it from looking like plastic. I rendered with caustics on and 16 bounces for glossy and transmission.
ghostship2 ( ) posted Fri, 23 December 2022 at 9:22 PM
still experimenting
ghostship2 ( ) posted Fri, 23 December 2022 at 9:45 PM
I think adding a bit more color to the ivory (more yellow) and then setting the transmission to .5 looks better
hborre ( ) posted Fri, 23 December 2022 at 9:45 PM
P13 PrincipledBsdf node?  It doesn't exist in P12, it has additional channels.
ghostship2 ( ) posted Fri, 23 December 2022 at 10:12 PM
Not using anything that ain't in P12.
Y-Phil ( ) posted Sat, 24 December 2022 at 1:13 PM · edited Sat, 24 December 2022 at 1:13 PM
Thank you sooooo much, Ghostship2... Wow
Here, I used Sasha's default teeth diffuse map and daz milwom V4AmyTeethB map.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Mac Mini M2, Sonoma 14.6.1, 16GB, 500GB SSD
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
Y-Phil ( ) posted Sat, 24 December 2022 at 1:15 PM
Beside's Ghosthip2 Ivory material, I've found on Rendo's market a Knee collection for Vic4, and Sasha, of course. Something that was missing, IMO.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
ghostship2 ( ) posted Sat, 24 December 2022 at 1:37 PM
@Y-Phil Those look great! Going back to saying that .4 transmission looks better but you can use whatever you think looks best.
Y-Phil ( ) posted Sat, 24 December 2022 at 2:27 PM
ghostship2 posted at 1:37 PM Sat, 24 December 2022 - #4452449
Thank you so much.
I'll make a test with .4
And Merry Christmas 😄
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
Y-Phil ( ) posted Sat, 24 December 2022 at 2:45 PM · edited Sat, 24 December 2022 at 2:45 PM
Indeed: I prefer 0.4:
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
hborre ( ) posted Sat, 24 December 2022 at 2:53 PM
Something worth experimenting with.  Thank you GS.
ghostship2 ( ) posted Sat, 24 December 2022 at 4:43 PM
@hborre Welcome!
shvrdavid ( ) posted Mon, 23 January 2023 at 4:16 PM
Just some doodles with La Femme.
Y-Phil ( ) posted Tue, 24 January 2023 at 2:51 AM
Gorgeous picture
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
Bastep ( ) posted Wed, 01 February 2023 at 4:14 PM
Victoria 4 and a lot of texture fiddling.
Y-Phil ( ) posted Thu, 02 February 2023 at 6:56 AM
Gorgeous
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
Liquid_Ice ( ) posted Thu, 23 February 2023 at 7:30 PM
Black and white render of Arya for antonia 1.3
hborre ( ) posted Thu, 23 February 2023 at 8:56 PM
Incredible texturing and detail.
Y-Phil ( ) posted Fri, 24 February 2023 at 1:35 AM
I agree with hborre: that's awesome
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
Liquid_Ice ( ) posted Fri, 24 February 2023 at 6:49 AM
Y-Phil posted at 1:35 AM Fri, 24 February 2023 - #4456765
Thank you, everything is handmade, the eyebrows are cones placed one by one, took ages.
Y-Phil ( ) posted Sat, 25 February 2023 at 11:51 AM
Liquid_Ice posted at 6:49 AM Fri, 24 February 2023 - #4456774
*fainting*
wow
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
Y-Phil ( ) posted Sun, 12 March 2023 at 6:11 PM · edited Sun, 12 March 2023 at 6:12 PM
Not bad for a 10 years old character, isn't it? zpieshP2zzmXqMjiwGufYML4emSP3cbc3sfuUj8B.gif
It's a Sahsa-16 character, with a second layer, anisotropy-based, for the skin, and Ghostship's Hair shader system on Afrodite's Kalla hair 🥰
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
hornet3d ( ) posted Mon, 13 March 2023 at 5:48 AM
Y-Phil posted at 6:11 PM Sun, 12 March 2023 - #4458242
Not Bad - great looking irrespective of the age of the figure.
Y-Phil ( ) posted Mon, 13 March 2023 at 7:50 AM
hornet3d posted at 5:48 AM Mon, 13 March 2023 - #4458279
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
hborre ( ) posted Wed, 15 March 2023 at 10:45 AM
I decided to dust off Sash-16 also after a long absence from rendering and posting.  The character is sporting Cycles Skin shaders built from the ground up.  The hair uses a modified Ghostship's, Hair Shader, with one of Ali's V4 hair models.  The background Japanese Bathhouse was completely retextured with PBR material because the originals were low-resolution diffuse-only images.  I added luminous lighting from a modified HDRI and one Sun infinite light with a Blackbody node attached set at 5600 degrees Kelvin; this constituted a more realistic lighting situation for the scene.  Depth of field was applied to give the scene more interest.
Y-Phil ( ) posted Wed, 15 March 2023 at 5:20 PM
hborre posted at 10:45 AM Wed, 15 March 2023 - #4458507
We're missing the "love button" so: great picture OytguCEv0QcxbUML6frU1eAl4h8M6c0xRSJHIppB.gif
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
vopehov506 ( ) posted Thu, 27 April 2023 at 8:03 AM · edited Thu, 27 April 2023 at 8:07 AM
exzazxe posted at 12:29 PM Sat, 12 November 2022 - #4449023
Liquid_Ice posted at 12:06 PM Sat, 12 November 2022 - #4449022
exzazxe posted at 2:02 PM Wed, 9 November 2022 - #4448809
Anyone knows of any teeth fixes for LF and LH?
What would you like to have changed?
Thanks for responding, I suppose what I should have asked after were teeth or mouth internal morphs rather than 'fixes'. They seem to be very spaced widely apart and the scale transforms don't seem to affect the spaces, I find the tongue very hard to pose.
I realise that the most likely solution is to export and model them and edit externally but it sure would be handy if someone already did that.
BTW sorry if interrupted the previous conversation on lighting technique
Actually never used LF , but seems that these teeth are looking a little weird, have not been made with care, or the creators did not take there time getting these right, who knows ! there is a old morphing teeth that was at RDNA, it could be used as replacement for LF and probably look allot better. I think it was made for V3 M3 at the time, so a older product .....
Sample
