Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 05 8:40 pm)
Delete them all - there's a script - or simply switch their values to zero.
Or on the properties tab, uncheck the on switch.
People, read the question! The OP wants to turn off ALL lights in the scene at once. Follow the Path in the screencap below:
Once the XLC Panel opens, right-click Light on the banner (highlighted) which will open the Parameters window, and there you will find the context field for turning on/off lights (highlighted).
This is how it's done in P11.
I did read the question. Can't see where it says "at once", though. Either way I suggested - and the others - work.
One other way :D
https://sharecg.com/v/57963/gallery/8/Script/Light-Toggle
Designed so you could set up working lights, toggle them off and set up the render lights, and then toggle back and forth as needed
Bill
my free light set here at Renderosity includes a preset that deletes all lights and one that loads three global lights that do not illuminate when rendered for those times you are using an HDRI or glowing objects.
https://www.renderosity.com/freestuff/items/86815/studio-lights-for-poser-12-and-poser-11
Is there a way to turn off all lights in Poser 11?
