Wed, Feb 12, 7:30 PM CST
Subject: Is there a way to turn off all lights in Poser 11?
chud ( ) posted Fri, 13 January 2023 at 2:11 AM · edited Tue, 11 February 2025 at 6:50 PM
SamTherapy ( ) posted Fri, 13 January 2023 at 4:56 AM
Delete them all - there's a script - or simply switch their values to zero.
RedPhantom ( ) posted Fri, 13 January 2023 at 7:22 AM
Site Admin
Or on the properties tab, uncheck the on switch.
hborre ( ) posted Fri, 13 January 2023 at 9:24 AM · edited Fri, 13 January 2023 at 9:24 AM
Online Now!
People, read the question!  The OP wants to turn off ALL lights in the scene at once.  Follow the Path in the screencap below:
Once the XLC Panel opens, right-click Light on the banner (highlighted) which will open the Parameters window, and there you will find the context field for turning on/off lights (highlighted).
This is how it's done in P11.
SamTherapy ( ) posted Fri, 13 January 2023 at 12:23 PM
I did read the question.  Can't see where it says "at once", though.  Either way I suggested - and the others - work.
hborre ( ) posted Fri, 13 January 2023 at 1:16 PM
Online Now!
It's a matter of implication but you are right, the OP was not explicitly clear about how to turn off the lights.  All should be good now; all the bases have been covered.
chud ( ) posted Fri, 13 January 2023 at 6:28 PM
Thank you. My apologies for not being clearer. :)
NikKelly ( ) posted Sun, 15 January 2023 at 11:27 AM
That's a useful trick, especially when you're trying to set a scene with 'luminous' stuff, as super-ambient and/or Cycles' emission.
willyb53 ( ) posted Fri, 12 May 2023 at 8:54 AM
One other way :D
https://sharecg.com/v/57963/gallery/8/Script/Light-Toggle
Designed so you could set up working lights, toggle them off and set up the render lights, and then toggle back and forth as needed
Bill
chud ( ) posted Sat, 13 May 2023 at 12:14 AM
Thanks willyb! That's precisely what I needed.
ghostship2 ( ) posted Sat, 13 May 2023 at 1:52 PM
Online Now!
my free light set here at Renderosity includes a preset that deletes all lights and one that loads three global lights that do not illuminate when rendered for those times you are using an HDRI or glowing objects.
https://www.renderosity.com/freestuff/items/86815/studio-lights-for-poser-12-and-poser-11
