Fri, Jan 10, 6:57 AM CST
Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2025 Jan 08 11:18 am)
banner
Subject: Scene with the set "Main Camera" and render black
RAGraphicDesign ( ) posted Fri, 27 January 2023 at 9:39 AM · edited Fri, 10 January 2025 at 6:57 AM
Hello everyone !
Since yesterday I have a problem in Poser 11 Pro that has never happened to me before...Did I do or touch something that I shouldn't have touched? What happens to me is that when I have the scene with the "Main Camera" set and I start the render what I get is a black rectangle. While if I opt for the "Posing Camera" I can have the normal render. Anyone have any ideas? Thanks for your help.
My Freestuff
hborre ( ) posted Fri, 27 January 2023 at 10:27 AM
Did you reset the Main Camera to its default settings?
feecozen ( ) posted Fri, 27 January 2023 at 12:32 PM
Where is the Main Camera positioned? This can happen if an object, like a visible ground plan or a wall, is between the Main Camera and the rest of the scene.
RAGraphicDesign ( ) posted Fri, 27 January 2023 at 1:43 PM
Thank you all ! The funny thing is that I had used the walls of this room before and I absolutely don't remember moving one of the walls...I'm definitely getting old..
If you want to see the reduced render you can see it HERE. Despite the wrong "Chamber" it didn't come out bad...
My Freestuff
Y-Phil ( ) posted Fri, 27 January 2023 at 4:13 PM · edited Fri, 27 January 2023 at 4:14 PM
Here is a little trick that can help to move the main camera correctly, or at least to retrieve it..  CvNXoEzMRgBN9SgvX5mQ5MKdxJOh1wZCF7k0lX6Y.gif
1. Switch to the top camera
2. In the Hierarchy window, activate the display of the cams
3. Select the main cam and make it visible
4. Go to the Menu: Display > Object Style, select one of the possibilities, example:
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
RAGraphicDesign ( ) posted Sat, 28 January 2023 at 3:21 AM
Thanks Y-Phil, advice much appreciated:)
My Freestuff
Y-Phil ( ) posted Sat, 28 January 2023 at 7:48 AM
RAGraphicDesign posted at 3:21 AM Sat, 28 January 2023 - #4454786
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
NikKelly ( ) posted Thu, 02 February 2023 at 12:56 PM
Yay !! Neat !!!
I often find some juggling of camera position plus camera's 'hither' setting allows sufficient suppression of 'photo-bomb' pillars, walls etc...
It's when entire scene renders black that the real head-scratching begins...
Y-Phil ( ) posted Fri, 03 February 2023 at 2:43 AM
NikKelly posted at 12:56 PM Thu, 2 February 2023 - #4455219
Yay !! Neat !!!
Indeed, we've all encountered such situations... j4BJaWSHYYZtG3siZ6RJIillDyXDSExLBvaOPKHA.gif
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
