Fri, Jan 31, 11:59 PM CST
Renderosity Forums / Poser 12
Welcome to the Poser 12 Forum
Poser 12 F.A.Q (Last Updated: 2025 Jan 26 3:18 pm)
Subject: Transfer / Import Cameras motion into Poser
Uncanny_Film ( ) posted Tue, 21 February 2023 at 3:50 PM · edited Sun, 26 January 2025 at 7:23 PM
How do I import a camera motion or animation, from another 3D application? I have an fbx file with camera animation. I want the same camera animation./motion. Can I put it in another application (Like Blender) and Export it as something that Poser will accept for camera animation?
Thanks,
Win10 - AMD 2nd Gen Ryzen Threadripper 2950X, 16-Core, 32 Thread 4.4 GHz - 128GB Ram - X2 GeForce RTX 3060 Ti - 3D-connexion
Poser 12 | Octane Render |  Real-Flow | 3DCoat | Speed Tree | Adobe Premiere  |  Adobe After Effects |  Adobe Audition |  Adobe Photoshop
nerd ( ) posted Wed, 22 February 2023 at 12:28 PM
Forum Moderator
 Poser doesn't import cameras from FBX but here's a trick to do it. In the app you're exporting from add a prop like a cone and parent the camera to the prop. Then export the scene and include the prop. Import the scene into Poser and parent a dolly camera to the imported prop at frame 1.You will need to aim the camera manually. But, now the camera will track the way it did in the source app.
Uncanny_Film ( ) posted Sat, 11 March 2023 at 7:14 PM
Thanks for the tip
ShaneNewville ( ) posted Sun, 23 April 2023 at 3:29 AM · edited Sun, 23 April 2023 at 3:37 AM
Uncanny_Film posted at 3:50 PM Tue, 21 February 2023 - #2977542
I came up with a weird trick that works (almost) perfectly getting camera animation from Blender to Poser while experimenting with virtual cams.
Basically we need to make a couple things to trick the apps into letting us use mocap data.  I imagine this can also work for fbx, but I used bvh.
1. in Blender create a new armeture with 1 bone and name it "hip".
2. add a bone constraint to it and set the target to the camera.  You should see the bone snap to the cam.
3. export a bvh file.  (bvh files need to at least have a bone for it to work)
4. In Poser I made a prop (which is missing now, but that's not important) and gave it a group named "hip" then in Setup Room gave it a single bone (hip).  I created this to be a single bone "figure" called CamFig.  (make sure to add it to your library for future)
5. The magic:  Select CamFig, set the Dolly Cam as child of the 'hip' then import the bvh file onto CamFig.
Its a bit of a work-around, but was successful.  The one issue I had was for some reason the Animation needed to be rotated 90 degrees on the X axis for the cam to look the in the correct direction (not rotate the hip bone as this would mess up the animation).    But once you get it right, you can bake all of the keys on the camera and then unparent it by dragging it back to UNIVERSE in the Hierarchy Editor.  the camera will retain all of the animation data.
_____________________________
My most recent Poser animation:
Previs Dummies 2
Uncanny_Film ( ) posted Sun, 23 April 2023 at 10:40 AM · edited Sun, 23 April 2023 at 10:46 AM
ShaneNewville posted at 3:29 AM Sun, 23 April 2023 - #4463127
Thanks, Shane. Got to love all these workarounds. LOL
ShaneNewville ( ) posted Thu, 27 April 2023 at 9:33 PM · edited Thu, 27 April 2023 at 9:38 PM
Uncanny_Film posted at 10:40 AM Sun, 23 April 2023 - #4463154
Its part of the charm of using Poser; the fact a sometimes janky work-arounds actually work.  I still prefer Poser for animation over industry standard 3d apps....though I do use them in the pipeline for other things.  There are just a lot of cool things that are made possible in Poser. I hope it never goes away.
Previs Dummies 2
