New Poser Users Help F.A.Q (Last Updated: 2025 Feb 07 1:07 pm)
Making the assumption you are using Superfly to render, another option, if you don't mind dropping into the material room, is to remove the alternate_ diffuse and alternate specular values. Superfly does not like/understand the alternates and it just bleaches out the material in question.
I use Poser 13 on Windows 11 - For Scene set up I use a Geekcom A5 - Ryzen 9 5900HX, with 64 gig ram and 3 TB storage, mini PC with final rendering done on normal sized desktop using an AMD Ryzen Threadipper 1950X CPU, Corsair Hydro H100i CPU cooler, 3XS EVGA GTX 1080i SC with 11g Ram, 4 X 16gig Corsair DDR4 Ram and a Corsair RM 100 PSU . The desktop is in a remote location with rendering done via Queue Manager which gives me a clearer desktop and quieter computer room.
I'm with Rhia on this one. Without any additional information from the OP, you're offering a shotgun approach as a solution. I totally disagree with the alternate_diffuse and alternate_specular channel statement, those connections can be controlled with an HSV2 node or converting the white chip to a greyscale color. Snarly's EZSkin3 uses those connectors for Superfly renders so there is no validity that Superfly does not like the alternates.
EzSkin 3 usually works fine on older figures, to make them suitable for SuperFly rendering. But if its use then leaves you with great-looking skin but white eye-pupils, then try:-
Material Room > Pupil material > Alternate Diffuse > follow to find its Scatter node > then turn the color there to a very dark grey (almost black).
Sorry should have kept my mouth shut. Perhaps I missed remembered but I was sure that is what I did when I had the problem when I first started using Superfly but somewhere along the way I converted to using the PhysicalSurface node so white eyes ceased to be and issue. I remember doing this manually but these days I would use Ken-1171_design's Go Physical script if I wanted to convert old materials.I'm with Rhia on this one. Without any additional information from the OP, you're offering a shotgun approach as a solution. I totally disagree with the alternate_diffuse and alternate_specular channel statement, those connections can be controlled with an HSV2 node or converting the white chip to a greyscale color. Snarly's EZSkin3 uses those connectors for Superfly renders so there is no validity that Superfly does not like the alternates.
All I can say is that I tried to make the old Poser Jessi 'as good as she could be' in 2022 in SuperFly. I used EZSkin to do that. Everything was fine, but her pupils went white. I used the alternate diffuse tweak to have them be a near-black again. It worked. Admittedly, she's a very old figure, so things might be different in later figures.
Since installing poser 12, all of my characters have totally white irises. This is true even for prior libraries. Please help. Thanks
