Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 11 2:52 am)
There is crossfitter. Older versions of Poser came with Wardrobe Wizard, but unless you got the supporting figure files already, you won't be able to use that because it's no longer sold. Newer versions of Poser come with the fitting room. Here's how to use that. This was written for Mike 4 to L'homme, but unless indicated, the steps should be the same
1.
1. Load figure. Turn off IKs. Use Figure>zero figure. (for L’Homme make sure the L’Homme size dial is set to zero.) Hide posing chips/control handles if applicable.Available on Amazon for the Kindle E-Reader Monster of the North and The Shimmering Mage
Do a google search for Evilinnocence's Crossdresser. It's free and supports many figures. You only pay for the license of the figure you want to convert TO and not FROM. There are several free licenses too so you can try it out first. It's fast, comes with a variety of options and is usually reliable. The Fitting room needs a lot of adjustments IMO that I have yet to fully understand. Usually the clothes just shrinkwrap for me and look nothing like the original, may be good for tight-fitting items but not for everything with my mediocre skills.
That's why in my instructions, you use the morph brush. Step 19 even says to ignore the tools in there. You only use it for the final conversion.
V4 and M4 have the same mesh topology. You can therefore load V4's mesh as an FBM into M4. You can then copy the morph to the clothing.
Results may not be optimal, but a good start. The morph brush can be used to correct any quirks.
Bone topology is also the same, so you can let the centres follow the morph.
Hey. I remember there was some ways for this but I could not find with some research here and there. Anyone can help me? Thx!
