Mon, Feb 3, 12:39 AM CST
Renderosity Forums / Poser 13
Welcome to the Poser 13 Forum
(Last Updated: 2025 Jan 31 3:19 pm)
Subject: Library is looking in the wrong place for Poser 13 Content.
hornet3d ( ) posted Thu, 13 April 2023 at 12:08 PM · edited Thu, 30 January 2025 at 11:44 AM
I was getting a warning that I was running short on disk space on my main 'C' drive so I tired to move or uninstall and reinstall some programs,  I ran Install Poser 13 program and at the appropriate point and allowed it to delete the existing Poser 13 installation, I selected the suggested option for the Poser 13 content files if you root drive was short of space.  All when well but Poser 13 is still looking for the content files in the drive 'C', I cannot delete these folders so how to I make Poser 13 look in the right place for content.
DCArt ( ) posted Thu, 13 April 2023 at 12:16 PM · edited Thu, 13 April 2023 at 12:17 PM
There is a screen in Setup where you are prompted to choose your Poser 13 content location.
When that screen pops up, I usually point it to my D drive. Just the top of the drive itself.
That will install the content to D:/Poser 13 Content.
Given that scenario, included content installed from the Library will get installed to D:/Poser 13 Content/Included/Runtime
And Purchased content installed from the library will get installed to  D:/Poser 13 Content/Purchases/Runtime
Rhia474 ( ) posted Thu, 13 April 2023 at 12:22 PM
Yiss! Thank you for spelling that out, i am getting there soon with C: and was dreading reinstall. Every other runtime is on my K: drive, this will help!
nerd ( ) posted Thu, 13 April 2023 at 1:15 PM
Forum Moderator
Also don't re-use your existing preferences if you reinstall and move the content. The old preferences will still expect the content to be in the old location. Use the "Backup existing preferences" choice during the re-install.
hornet3d ( ) posted Thu, 13 April 2023 at 1:16 PM
DCArt posted at 12:16 PM Thu, 13 April 2023 - #4462045
Which is what I did during set up, I sent it to my M drive.  When I launch the Library it  has nothing in Poser 13 content , if right click and select show in explorer it points toe the C drive location.
Y-Phil ( ) posted Thu, 13 April 2023 at 1:47 PM · edited Thu, 13 April 2023 at 1:49 PM
hornet3d posted at 1:16 PM Thu, 13 April 2023 - #4462049
And if you're not afraid to edit an XML file, for example using notepad. Make a backup before, just to be sure.
- open up your file explorer
- go to %appdata%\poser\13
- edit LibraryPrefs.xml
- adapt the path accordingly to where it's actually stored, but indeed preferably not on the C drive
Example with mine:
Oh and while you're there, check poser.ini, especially the line with CONTENT_INSTALL_RUNTIME = ...
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
hornet3d ( ) posted Thu, 13 April 2023 at 2:31 PM
Y-Phil posted at 1:47 PM Thu, 13 April 2023 - #4462056
Example with mine:
Thank you so much you are a savior, it took me two attempts as I missed one line on the first go but it worked second time.  I guess you cannot put the Poser 13 content on a different drive in the setup and also check the use existing preferences.  Whatever I did with the drive the install program created a Poser 13 content in the usual place on the C drive but then did not populate it.
Anyway, thanks to you and after about seven reinstalls I am back working,  I cannot tell you how much I appreciate your help.
Y-Phil ( ) posted Thu, 13 April 2023 at 2:37 PM · edited Thu, 13 April 2023 at 2:37 PM
hornet3d posted at 2:31 PM Thu, 13 April 2023 - #4462068
Since such a long time that I can't remember when, I've always have my runtimes stored on any drive but never on the C: as the permissions are... sensitive at least
Now, Poser12 is in its own folder, Poser13 in its own one, too, and the runtimes collection lie not far away, on the same SSD drive:
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
Thalek ( ) posted Fri, 14 April 2023 at 10:52 AM
Yeah, even when you put your content on another drive, installation still creates a bare bones runtime on your C: drive.  And as you both pointed out, if you re-use your old preferences file, it still looks in all the old familiar places for your content, then gets very depressed when it can't find it.  I always had a small C: drive, so I've been putting my content on another, larger drive ever since Poser started letting us do it.  Because of that, I've never had a chance to make that particular mistake with the preferences, but believe me, I would have done the same thing if I'd had to move stuff and re-install. After all, my preferences are set up the way I want them . . . why do it all over again?  Well, now we know why we should consider doing it all over again, at least after rearranging locations. As I said, it would never have occurred to me not to.
Y-Phil ( ) posted Fri, 14 April 2023 at 1:59 PM
I've been installing Poser so often that I'm doing it almost automatically, so that  I can't remember the details but:
1. among the first questions, the install procedure asks you where to install Poser => not on the C: drive thanks - lol
2. then another question appear (later?) and I know that I select the second option ("install on another drive" or something like that) because the default option (the first) will drop the runtime on a public, shared folder, and that's a "No! thanks, once again" 'cause this folder structure lies in fact most of the time on the C: drive, under "C:\Users" if I'm not wrong, that's the moment when I ask the procedure to put the content runtime onto "P:\Poser\Runtimes", this part of the install procedure maintains the "Poser 13 Content" part of the full name
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
hornet3d ( ) posted Fri, 14 April 2023 at 2:29 PM
Y-Phil posted at 1:59 PM Fri, 14 April 2023 - #4462175
Yep I did all that and Poser still looked to the 'C' drive for the Poser 13 content which is why I think asking the install to use existing preferences might be the issue.
Y-Phil ( ) posted Fri, 14 April 2023 at 3:19 PM
did you check the poser.ini, as explained yesterday?
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
hornet3d ( ) posted Fri, 14 April 2023 at 4:44 PM
Y-Phil posted at 3:19 PM Fri, 14 April 2023 - #4462189
Yes thanks, as I posted yesterday I was able to use your screen shots to work out what I needed to do with my poser.ini and it is all working well now.  I was just speculating on why nothing else would work.
Anyway, all fixed thanks to you so thanks for the help, not only was i able to fix it but I learnt something along the way.
Y-Phil ( ) posted Fri, 14 April 2023 at 4:49 PM
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
