Wed, Jan 8, 9:28 PM CST
Renderosity Forums / Poser 12
Welcome to the Poser 12 Forum
Poser 12 F.A.Q (Last Updated: 2025 Jan 08 5:19 pm)
Subject: import FBX with animations into Poser 12
Uncanny_Film ( ) posted Sun, 19 February 2023 at 7:18 PM · edited Wed, 08 January 2025 at 7:47 AM
How do I import FBX animations into Poser 12?  In poser 11 when you import FBX with an animation it plays with the rigged figure. But in Poser 12 when I import an FBX with animation it just has the rigged model and T pose.
Is there an option or setting I'm missing?
Win10 - AMD 2nd Gen Ryzen Threadripper 2950X, 16-Core, 32 Thread 4.4 GHz - 128GB Ram - X2 GeForce RTX 3060 Ti - 3D-connexion
Poser 12 | Octane Render |  Real-Flow | 3DCoat | Speed Tree | Adobe Premiere  |  Adobe After Effects |  Adobe Audition |  Adobe Photoshop
nerd ( ) posted Sun, 19 February 2023 at 8:41 PM
Forum Moderator
I haven't used the FBX import in a while so I had to make sure it hadn't got broken. It imported the animation as expected. Where did the FBX come from?
Uncanny_Film ( ) posted Sun, 19 February 2023 at 8:51 PM
nerd posted at 8:41 PM Sun, 19 February 2023 - #4456344
I got the fbx from Adobe Maximo site.
Uncanny_Film ( ) posted Tue, 21 February 2023 at 3:42 PM
Heres the file.
https://drive.google.com/file/d/1BRS4kZ2ueoSTmwpTOLDG_P54VttRhclf/view?usp=sharing
Uncanny_Film ( ) posted Thu, 09 March 2023 at 5:12 PM
Does no one have an answer?
EVargas ( ) posted Fri, 10 March 2023 at 1:30 PM
Hi, it is possible that the FBX version of the file is too old. I was able to import it into Poser 12, after importing/exporting from SideFX Houdini as FBX v2020.
Try converting the original FBX to a recent format, it seems that will help you. It is possible Autodesk has something for this I don't know.
EVargas.Art
EVargas ( ) posted Fri, 10 March 2023 at 2:17 PM · edited Fri, 10 March 2023 at 2:17 PM
There is another thing you can try, it worked for me: while comparing the original and the one converted via Houdini I notice that in the bone names, I noticed that double dots ":" was replaced by underline "_". So I opened the original in text editor, search/replaced "mixamorig:" to "mixamorig_", save as copy, now it imported in P12 as expected too!
EVargas.Art
Uncanny_Film ( ) posted Sat, 11 March 2023 at 10:15 AM
evargas posted at 2:17 PM Fri, 10 March 2023 - #4458075
Which text editor did you use? I used word pad and office word and after saving the file it wouldn't open in poser or even windows.
EVargas ( ) posted Sat, 11 March 2023 at 11:42 AM
Notepad++ on Windows PC, https://notepad-plus-plus.org/downloads/
I tested today again just to make sure, yes it works, replace all then save it:
EVargas.Art
Uncanny_Film ( ) posted Sat, 11 March 2023 at 7:11 PM
Thanks it worked
ShaneNewville ( ) posted Sun, 23 April 2023 at 3:40 AM · edited Sun, 23 April 2023 at 3:41 AM
evargas posted at 11:42 AM Sat, 11 March 2023 - #4458123
OOh that's a good tip to remember.  Ive run into a few instanced where something had to be renamed in a bvh file too in order to work.  nice.
I didn't know we could edit files in text when they were in the format with "NUL" or other odd characters without corrupting things.  Good to know
_____________________________
My most recent Poser animation:
Previs Dummies 2
NikKelly ( ) posted Sun, 23 April 2023 at 10:18 AM
Thank you for that info about Notepad++.
Why that should work but neither Notepad nor Wordpad is interesting...
Also, have you tried any of the Truebones' animated FBX freebies ??
I do not know if he's 'just lucky' or uses Autodesk's official SDK, but his FBX models and conversions all seem to 'Play Nice' with my P_11.3...
Disclosure: I bought Truebone's 'PMX to FBX' Converter ($$) to get rigged MMD figures into Poser. IIRC, it also ports animation.
Two 'gotchas'...
This first version cannot port texture calls. Hand-loading those within Poser may be tedious, but totally beats trying to rig figure..
Do NOT port PMX models flagged 'TDA' or 'TDA-derived', as their 'T&Cs' prohibit use outside MMD environment.
IIRC, TDA's author was badly affected by SL piracy, slammed the door...
