(Last Updated: 2025 Feb 07 10:51 am)
I am not seeing that on my system, it immediately stated it is cancelling and odes so after 10 seconds or so. The only problem I am having is Poser going walk about with the CPU showing high usage but nothing appearing to be happening in Poser. Problem often occurs if I have been working on a scene and then take the 'New' route from the file tab, if I shut down Poser and then load the same scene form scratch there are no issues. It is almost as though Poser is not letting go of the old scene.
I use Poser 13 on Windows 11 - For Scene set up I use a Geekcom A5 - Ryzen 9 5900HX, with 64 gig ram and 3 TB storage, mini PC with final rendering done on normal sized desktop using an AMD Ryzen Threadipper 1950X CPU, Corsair Hydro H100i CPU cooler, 3XS EVGA GTX 1080i SC with 11g Ram, 4 X 16gig Corsair DDR4 Ram and a Corsair RM 100 PSU . The desktop is in a remote location with rendering done via Queue Manager which gives me a clearer desktop and quieter computer room.
Ive run into this too. For test sake, next time it hangs, see what happens if you press Alt+F4 (make sure you saved your work before attempting, or try with a test scene).I tried the same file in Poser 12, and it's fine. Click "cancel," and the render cancels nearly instantly.
But with Poser 13, it just hangs. Task Manager shows CPU usage is high, but nothing seems to be happening. Maybe it would resolve eventually, but after several minutes, I killed Poser. Tried it again after rebooting, same results.
_____________________________
My most recent Poser animation:
Previs Dummies 2
randym77 posted at 5:12 PM Thu, 27 April 2023 - #2979035Yes, that's what happens! Though Poser freezes for more than a few seconds. Maybe a minute or so. But then it works fine. Superfly seems to render a lot faster afterwards, too.Ive run into this too. For test sake, next time it hangs, see what happens if you press Alt+F4 (make sure you saved your work before attempting, or try with a test scene).I tried the same file in Poser 12, and it's fine. Click "cancel," and the render cancels nearly instantly.
See if instead of forcing Poser closed (as Alt+F4 normally would), see if it cancels render, freezes Poser for a few seconds, and then go back to normal. If it does, now try to render with Superfly against and then also cancel it again once it starts. Curious if we are getting the same results.
The first time after Poser installs, or after you update some specific drivers on your computer, Poser needs to rebuild render kernels. This can take some minutes to do, and then it won't do that again unless something (installation/drivers) changes.
If you're rendering directly, Poser will say it's building render kernels in the progress bar of the render, but if you're rendering on background, nothing will warn you of this, it'll just build the kernels, and it might feel frozen or crash if you interrupt it. Could this be what's going on?
Feel free to call me Ohki!
That's a bit above my knowledge - no idea, sorry xDCould be. But what does it mean if I've shut down Poser using the task manager during the process? Does that mean the kernels aren't fully built or something?
randym77 posted at 5:12 PM Thu, 27 April 2023 - #2979035Quoting myself since Edit is not an option.Ive run into this too. For test sake, next time it hangs, see what happens if you press Alt+F4 (make sure you saved your work before attempting, or try with a test scene).I tried the same file in Poser 12, and it's fine. Click "cancel," and the render cancels nearly instantly.
Previs Dummies 2
Here's what I suspect:
- I installed Poser13 last April 7
- an update took place on April 12th, around 23h30
And if I take a look the the "gpu" folder, in the "Runtime" folder, but the one located where the executable lies, there are two binary files with the same date/hour of modification:
It's probably already managed in Poser, at a programming level but I suspect that these files are automatically rebuilt if they are missing or invalid.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Win11 on i9-13900K@5GHz, 64GB, RoG Strix B760F Gamng, Asus Tuf Gaming RTX 4070 OC Edition, 1 TB SSD, 6+4+8TB HD
👿 Mac Mini M2, Sequoia 15.2, 16GB, 500GB SSD
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
