(Last Updated: 2025 Feb 13 3:42 pm)
I agree with Rae! You stated you thought it looked dull. Well these little pick me ups you added in Postwork def made it pop and looks really lovely!
---Wolff On The Prowl---
running some tests with the DS bridge I been working at, actually for prior poser but now for P13 in combination with the sunlight i am setting up.
DS articulated Product in Poser 13 Superfly ( Bridge Import )
Advantages to DS ... allot faster rendering, not that heavy on the system, extreme high details.
@vopehov506, this looks very good.
What do you want the DS Bridge being capable of?
Full Import features for Props and Figures, including the transfer of textures seems too much to ask, I guess?
This is a Sydney morph for Lafemme, that I recently made for RedPhantom.
The topology is very different between the figures, I think it came out pretty good thou. It is not perfect, but follows the face very close.
It is made with 2 morphs, one at the default level, then an HD one on top of it so it will follow Sydney's face a lot better.
These are my body morphs as well, but I made those a while ago.
Some things are easy to explain, other things are not........ <- Store -> <-Freebies->
blackbonner posted at 3:44 PM Fri, 12 May 2023 - #4465102
The setup I'm working at is slowly fully working, the scene and creature above are direct imports, there was no more need to make any material setups nor corrections, right out of the box! So not a export of DS. It is something I like working at, bridging different programs together, finding solutions to combine programs I work at to communicate. But actually not that much into DS, I like the models they make but not using DS. I am already trying to adapt it in the opposite direction since quiet a while but never found the right solutions, DS to Poser works perfectly, but after some evolution it does not seem to work quiet well in Poser to DS. I always say Poser eats it all, actually incredible, the hardest part is always the opposite direction, but for other programs I already found for most communications the solutions.@vopehov506, this looks very good.
It is sure possible to export in different formats and reimport in Poser but this is the long path that often does not give the best results. Bridging is the best one from my point of view and a real time saver.
When I get some time I'll want to get a little into Reallusion, to see if it is also possible building up a reasonable communication with Poser ! challenging stuff. Time is mostly the main issue, right now taking apart this Poser13 and yes it could have some future, I just do not feel very comfortable with that call home feature and the large amont of the hard coded hyperlinks in the starter, as for the rest it is ok.
The castle... well there I noted that the water could be a little better or would need to be adjusted manually. The Laps there I only increased a little the emissions, but less would of been better to keep there details.
WOW, that is some morph, your skills leaves me almost speechless.This is a Sydney morph for Lafemme, that I recently made for RedPhantom.
I use Poser 13 on Windows 11 - For Scene set up I use a Geekcom A5 - Ryzen 9 5900HX, with 64 gig ram and 3 TB storage, mini PC with final rendering done on normal sized desktop using an AMD Ryzen Threadipper 1950X CPU, Corsair Hydro H100i CPU cooler, 3XS EVGA GTX 1080i SC with 11g Ram, 4 X 16gig Corsair DDR4 Ram and a Corsair RM 100 PSU . The desktop is in a remote location with rendering done via Queue Manager which gives me a clearer desktop and quieter computer room.
Great work, both on the bridge and the render.running some tests with the DS bridge I been working at, actually for prior poser but now for P13 in combination with the sunlight i am setting up.
Excellent!Couldn't knock before you come in???
Test with motion blur...
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Win11 on i9-13900K@5GHz, 64GB, RoG Strix B760F Gamng, Asus Tuf Gaming RTX 4070 OC Edition, 1 TB SSD, 6+4+8TB HD
👿 Mac Mini M2, Sequoia 15.2, 16GB, 500GB SSD
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
JanusJsenwark posted at 4:18 AM Sat, 13 May 2023 - #4465171
Hey... You just killed me with the new poster on the wall.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
@JanusJsenwark, hilarious and it is prove of the scientific fact that states, chocolate makes people happy.
And yes, there is someone out there, but she's in a phone call right now...
I thought I would post another one of my Poser 13 renders in this Poser 13 Render thread.
That is what the thread is actually for after all......
As you can see, I am still playing around with the Sydney morph I made for LaFemme.
What Poser figure should I do a morph for next?
Not the sort of creature you would want to meet anywhere or at anytime, great render.He's hungry
Believe it or not, that is a V3 updo hairdo that I tweaked the trans map on to a much higher size and detail. Sometimes old content work well with a few tweaks.
This morph is a combination of 6 morphs, a base shape then 5 HD morphs on top of it to define the shape better. And that is just for the face.....
There is not a lot of topology in LaFemme's face, so you need some SubD love to do a lot with certain areas.
Someday I should do a tutorial on how I do these SubD morphs in Poser. But I don't know if other people even use SubD morphs in Poser.
Do any of you use the SubD morph features in Poser? And if you do, what would you like to see added to the toolset?
If there is enough interest we can start a thread specifically on SubD morphs. Possibly even a tutorial, possibly, lol...
No quads were harmed in the making of these morph.....
Yep, count me in.I would be very interested in this workflow. I think others would too.
I'm interested as well
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
I'd be interested too.
Location Content purchased by me in 2017.
Made a little test render in P13 one with Superfly and one with LUX
Superfly version in P13
And This is the LUX engine in P13
Both using GPU Render time was about 6min Superfly and 4 min LUX. Quality is approx. the same probably depends on setting and lights these are just simple setups. You naturally get allot more features in LUX but this is quiet a learning curve.
I mistook him for Samuel L. Jackson.Thanks for the attention. I couldn't resist letting Morgan Freeman take a look.
shvrdavid posted at 10:16 AM Mon, 15 May 2023 - #4465372
She's beautiful, and so is the hair.
I confess that at the moment, I don't do SubD morphs, and I don't know how much I would use them if you did a tutorial; I haven't done a lot of morphs, period. But I will say that one of the reasons I don't do SubD morphs is that I don't know anything about them.
Do as you will, of course, but think of how many people might benefit from such a tutorial, people who don't know where to ask, or are intimidated by the process before they've tried. Whatever you decide, do it (or don't do it) because it makes you happy. Everything after that is gravy.With shvrdavid's help (he did all the heavy lifting) I've been able to modernize one of my characters.
Those colors really pop! Lovely and evocative, thank you!
