Mon, Feb 10, 11:49 AM CST
Renderosity Forums / Poser 13
Welcome to the Poser 13 Forum
(Last Updated: 2025 Feb 10 10:51 am)
Subject: Show your Poser 13 renders!
Rhia474 ( ) posted Fri, 12 May 2023 at 6:58 AM
TheAnimaGemini posted at 1:56 PM Thu, 11 May 2023 - #4464992
Here I have a still live image. Was doing some experiments with the shader. Not really satisfied, to be honest, with my work. Postwork is some contrast and little saturation.
For some reason, it came out from Poser very dull, even when on the screen pretty fine.
Those colors really pop! Lovely and evocative, thank you!
RAMWorks ( ) posted Fri, 12 May 2023 at 10:08 AM
I agree with Rae!  You stated you thought it looked dull.  Well these little pick  me ups you added in Postwork def made it pop and looks really lovely!
---Wolff On The Prowl---
My Store is HERE
My Freebies are HERE
vopehov506 ( ) posted Fri, 12 May 2023 at 1:41 PM · edited Fri, 12 May 2023 at 1:46 PM
running some tests with the DS bridge I been working at, actually for prior poser but now for P13 in combination with the sunlight i am setting up.
DS articulated Product in Poser 13 Superfly ( Bridge Import )
Advantages to DS ... allot faster rendering, not that heavy on the system, extreme high details.
vopehov506 ( ) posted Fri, 12 May 2023 at 2:56 PM · edited Fri, 12 May 2023 at 2:56 PM
DS bridged, Castle test, in combination with the extended sunlight emission and the space dome for sun Planets and stars.
blackbonner ( ) posted Fri, 12 May 2023 at 3:44 PM
@vopehov506, this looks very good.
What do you want the DS Bridge being capable of?
Full Import features for Props and Figures, including the transfer of textures seems too much to ask, I guess?
shvrdavid ( ) posted Fri, 12 May 2023 at 4:19 PM
This is a Sydney morph for Lafemme, that I recently made for RedPhantom.
The topology is very different between the figures, I think it came out pretty good thou. It is not perfect, but follows the face very close.
It is made with 2 morphs, one at the default level, then an HD one on top of it so it will follow Sydney's face a lot better.
These are my body morphs as well, but I made those a while ago.
shvrdavid ( ) posted Fri, 12 May 2023 at 4:48 PM
Closer shot of her.
Y-Phil ( ) posted Fri, 12 May 2023 at 5:50 PM
shvrdavid posted at 4:48 PM Fri, 12 May 2023 - #4465111
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
vopehov506 ( ) posted Fri, 12 May 2023 at 5:58 PM · edited Fri, 12 May 2023 at 6:07 PM
blackbonner posted at 3:44 PM Fri, 12 May 2023 - #4465102
The setup I'm working at is slowly fully working, the scene and creature above are direct imports, there was no more need to make any material setups nor corrections, right out of the box! So not a export of DS. It is something I like working at, bridging different programs together, finding solutions to combine programs I work at to communicate. But actually not that much into DS, I like the models they make but not using DS. I am already trying to adapt it in the opposite direction since quiet a while but never found the right solutions, DS to Poser works perfectly, but after some evolution it does not seem to work quiet well in Poser to DS.  I always say Poser eats it all, actually incredible, the hardest part is always the opposite direction, but for other programs I already found for most communications the solutions.
It is sure possible to export in different formats and reimport in Poser but this is the long path that often does not give the best results. Bridging is the best one from my point of view and a real time saver.
When I get some time I'll want to get a little into Reallusion, to see if it is also possible building up a reasonable communication with Poser ! challenging stuff. Time is mostly the main issue, right now taking apart this Poser13 and yes it could have some future, I just do not feel very comfortable with that call home feature and the large amont of the hard coded hyperlinks  in the starter, as for the rest it is ok.
The castle... well there I noted that the water could be a little better or would need to be adjusted manually. The Laps there I only increased a little the emissions, but less would of been better to keep there details.
hornet3d ( ) posted Fri, 12 May 2023 at 8:01 PM
shvrdavid posted at 4:19 PM Fri, 12 May 2023 - #4465108
WOW, that is some morph, your skills leaves me almost speechless.
hornet3d ( ) posted Fri, 12 May 2023 at 8:02 PM
vopehov506 posted at 1:41 PM Fri, 12 May 2023 - #4465094
Great work, both on the bridge and the render.
Thalek ( ) posted Fri, 12 May 2023 at 10:38 PM
jura11 posted at 9:22 PM Thu, 11 May 2023 - #4465042
Here is render of TruForm Industrial Loft with my props and textures,rendered in Poser 13
Your work is incredibly detail-oriented!
shvrdavid ( ) posted Sat, 13 May 2023 at 2:38 AM · edited Sat, 13 May 2023 at 2:38 AM
Content Advisory! This message contains nudity, violence
Bang....
GiveitUp ( ) posted Sat, 13 May 2023 at 4:17 AM
Couldn't knock before you come in???i5rv9X2M4SRnIYjmWpw5iY2IJKYfcrujoj0dWG5K.jpg
Test with motion blur...
GiveitUp ( ) posted Sat, 13 May 2023 at 4:18 AM
GVFqWXlkMCrmps2N9gt3YMXU7vE6SKpPaiDtdt6O.jpg.
GiveitUp ( ) posted Sat, 13 May 2023 at 5:04 AM
Sorry!!!
hornet3d ( ) posted Sat, 13 May 2023 at 5:24 AM
shvrdavid posted at 2:38 AM Sat, 13 May 2023 - #4465166
Bang....
Nice shooters....sorry shooter.
hornet3d ( ) posted Sat, 13 May 2023 at 5:25 AM
JanusJsenwark posted at 4:18 AM Sat, 13 May 2023 - #4465171
Superb Renders.
Y-Phil ( ) posted Sat, 13 May 2023 at 8:08 AM
Bang....
Gorgeous wow
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
JanusJsenwark posted at 4:17 AM Sat, 13 May 2023 - #4465170
Excellent!
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
Y-Phil ( ) posted Sat, 13 May 2023 at 8:09 AM
Hey... You just killed me with the new poster on the wall
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
GiveitUp ( ) posted Sat, 13 May 2023 at 8:42 AM
Thanks for the attention. I couldn't resist letting Morgan Freeman take a look.
GiveitUp ( ) posted Sat, 13 May 2023 at 11:18 AM
GiveitUp ( ) posted Sat, 13 May 2023 at 1:55 PM · edited Sat, 13 May 2023 at 1:55 PM
I was sure I had put the key on the chest of drawers in the hallway. hmm...96QMb0UzXgqf2j6eKmz6gaUxnHfPO0mk6iFebya7.jpg
GiveitUp ( ) posted Sun, 14 May 2023 at 6:36 AM
GiveitUp ( ) posted Sun, 14 May 2023 at 7:17 AM
iwhcQTI3un2O5Gqy76rmo01DhnUarl9AU4BjcwG2.jpg?
GiveitUp ( ) posted Sun, 14 May 2023 at 7:43 AM · edited Sun, 14 May 2023 at 7:43 AM
blackbonner ( ) posted Sun, 14 May 2023 at 9:57 AM · edited Sun, 14 May 2023 at 9:57 AM
@JanusJsenwark, hilarious and it is prove of the scientific fact that states, chocolate makes people happy.
And yes, there is someone out there, but she's in a phone call right now...
vopehov506 ( ) posted Sun, 14 May 2023 at 11:47 AM
After some really bad crashes and quiet some configurations .... just wanted it to run  Version 3 works with fixes version 4 no chance have no Idea why ....
vopehov506 ( ) posted Sun, 14 May 2023 at 4:01 PM
ok just got Reality 4 running  4.2 or 4.3 keeps on crashing ..... almost messed up my whole poser for this ! Spits out really neat renders and surprised how fast !
shvrdavid ( ) posted Sun, 14 May 2023 at 5:02 PM
I thought I would post another one of my Poser 13 renders in this Poser 13 Render thread.
That is what the thread is actually for after all......
As you can see, I am still playing around with the Sydney morph I made for LaFemme.
What Poser figure should I do a morph for next?
GiveitUp ( ) posted Sun, 14 May 2023 at 5:17 PM · edited Sun, 14 May 2023 at 5:17 PM
vopehov506 ( ) posted Sun, 14 May 2023 at 6:13 PM · edited Sun, 14 May 2023 at 6:13 PM
He's hungry
vopehov506 ( ) posted Sun, 14 May 2023 at 6:43 PM · edited Sun, 14 May 2023 at 6:44 PM
Torch Light
shvrdavid ( ) posted Sun, 14 May 2023 at 10:33 PM
Yes, that is LaFemme.
hornet3d ( ) posted Sun, 14 May 2023 at 10:36 PM
shvrdavid posted at 10:33 PM Sun, 14 May 2023 - #4465340
Impressive
hornet3d ( ) posted Sun, 14 May 2023 at 10:37 PM
vopehov506 posted at 6:13 PM Sun, 14 May 2023 - #4465327
He's hungry
Not the sort of creature you would want to meet anywhere or at anytime, great render.
Y-Phil ( ) posted Mon, 15 May 2023 at 1:34 AM
Gorgeous 😍
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
shvrdavid ( ) posted Mon, 15 May 2023 at 10:16 AM · edited Mon, 15 May 2023 at 10:16 AM
Believe it or not, that is a V3 updo hairdo that I tweaked the trans map on to a much higher size and detail. Sometimes old content work well with a few tweaks.
This morph is a combination of 6 morphs, a base shape then 5 HD morphs on top of it to define the shape better. And that is just for the face.....
There is not a lot of topology in LaFemme's face, so you need some SubD love to do a lot with certain areas.
Someday I should do a tutorial on how I do these SubD morphs in Poser. But I don't know if other people even use SubD morphs in Poser.
Do any of you use the SubD morph features in Poser? And if you do, what would you like to see added to the toolset?
If there is enough interest we can start a thread specifically on SubD morphs. Possibly even a tutorial, possibly, lol...
No quads were harmed in the making of these morph.....
hborre ( ) posted Mon, 15 May 2023 at 10:54 AM
I would be very interested in this workflow.  I think others would too.
hornet3d ( ) posted Mon, 15 May 2023 at 1:14 PM
hborre posted at 10:54 AM Mon, 15 May 2023 - #4465377
Yep, count me in.
GiveitUp ( ) posted Mon, 15 May 2023 at 1:48 PM
Through the night with Steffi. It smells of leather and coconut suntan lotion.
Aston Martin One77
Y-Phil ( ) posted Mon, 15 May 2023 at 2:04 PM
shvrdavid posted at 10:16 AM Mon, 15 May 2023 - #4465372
I'm interested as well
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
RedPhantom ( ) posted Mon, 15 May 2023 at 2:36 PM
Site Admin
I'd be interested too.
hornet3d ( ) posted Mon, 15 May 2023 at 2:51 PM · edited Mon, 15 May 2023 at 2:51 PM
Location Content purchased by me in 2017.
vopehov506 ( ) posted Mon, 15 May 2023 at 2:56 PM · edited Mon, 15 May 2023 at 2:56 PM
Made a little test render in P13 one with Superfly and one with LUX
Superfly version in P13
And This is the LUX engine in P13
Both using GPU Render time was about 6min Superfly and 4 min LUX. Quality is approx. the same probably depends on setting and lights these are just simple setups. You naturally get allot more features in LUX but this is quiet a learning curve.
Thalek ( ) posted Mon, 15 May 2023 at 3:22 PM
JanusJsenwark posted at 8:42 AM Sat, 13 May 2023 - #4465188
I mistook him for Samuel L. Jackson.
Thalek ( ) posted Mon, 15 May 2023 at 3:33 PM
She's beautiful, and so is the hair.
I confess that at the moment, I don't do SubD morphs, and I don't know how much I would use them if you did a tutorial; I haven't done a lot of morphs, period.  But I will say that one of the reasons I don't do SubD morphs is that I don't know anything about them.
Do as you will, of course, but think of how many people might benefit from such a tutorial, people who don't know where to ask, or are intimidated by the process before they've tried.  Whatever you decide, do it (or don't do it) because it makes you happy.  Everything after that is gravy.
RedPhantom ( ) posted Mon, 15 May 2023 at 5:12 PM · edited Mon, 15 May 2023 at 5:12 PM
Site Admin
With shvrdavid's help (he did all the heavy lifting) I've been able to modernize one of my characters.
vopehov506 ( ) posted Mon, 15 May 2023 at 6:29 PM
another test trying to remove the flatness in the renders  ( Lux p13 ) 2min render
