(Last Updated: 2025 Feb 12 4:20 am)
ghostship2 posted at 4:59 PM Wed, 17 May 2023 - #4465619
Sorry but I'm not sure to understand, I mean: that allows me to select a color as not all brows are black.A closure with just a color chip plugged into one side makes no sense.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Win11 on i9-13900K@5GHz, 64GB, RoG Strix B760F Gamng, Asus Tuf Gaming RTX 4070 OC Edition, 1 TB SSD, 6+4+8TB HD
👿 Mac Mini M2, Sequoia 15.2, 16GB, 500GB SSD
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
Color plugged into what though? It's not plugged into a diffuse, reflect or anything else. The way those mix closures work is you want two shaders plugged in and then you'd have that color chip plugged into one of the shaders. the other shader would be your SSS setup that you have there
I'm not doubting of your knowledge, that's sure, I'm just trying to understand, once again sorry about that.
But if I change the color of the "Input Color" node, the brows are getting a new color.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
I think what Ghostshio is saying is that usually you use a shader node in a mixclosure. It's for combining shader nodes (nodes under the shader category) rather than other nodes. In this case, the "proper" way would be to have the color node plugged into a diffusebsdf node. Though, theoretically, the diffuse has its own color chip so you could just use that to change the eyebrow color.
If I guessed correctly, I should replace the Color Ship by a PrincipleBSDF one?
I've tested this:
And indeed that gives a better result (above: Color node, below: PBSDF)
Thank you!
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
Oh... I misread what RedPhatom wrote, sorry about that. I like what I'm getting now. Thank you.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
Speaking of lips mask: I'm using yours, Ghostship2, but still find that line around the lips, probably because the color of the lips itself doesn't extend enough.
Sometimes it's supportable, sometimes not.
Here, I can do with
I've tried to play with the Scatter Group ID but I haven't succeed to remove that line.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
Here is my setup, inspired by yours:
Note that the Face Skin Scatter Group ID = 1
The Lips Mask is yours.
The Subsurface radius is 0.482, 0.169, 0.109, but I'm getting the same effect with your values
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
And if I use Scatter Group ID=1 for the face in the setup here, I'm loosing that weird greenish line but will what I call a kind of moustache line
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
OK, I think I miss-typed some roughness values in the SSS shader setup. I think I said increase roughness by 1. I meant to say .1. I think your roughness values are way too high and also your lip bump values. I get a nice smooth transition between the lip and the face skin
After having corrected the values, indeed, I'm getting this
But I thought I could get rid of was what the green arrows are showing, but after having experimented a bit with different lips masks, I found that something is wrong at the bitmap level because the shape of of lips is smaller than what is on the bitmaps, and it's a parameter that can't be changed using morphs.
Here I replaced the face bitmap by a simple color on the Lips material:
I Suppose that it's something that should be corrected on the bitmap, actually not doable by me (already tried - lol)
Never mind, i'll live with this... "moustache" Thank you anyway for your help.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
From what I've understood, the Scatter Group ID could be used to avoid weird effects when using SSS on overlapping surfaces, but in V13.0.339, there's a new "Legacy Scatter" checkbox that can help (avoids SSS glow)
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
@Y-Phil
Open the face map in Photoshop. Copy the map to a second layer. Erase everything on the second layer but the mouth. Enlarge the mouth on layer 2. Make sure to use a soft brush when erasing. Make sure the new lips are in the right place and collapse the layers and save the image with a new name.
Aha... I promise that I'll test this tomorrow, when my brain will be rested (half past midnight for me)@Y-Phil
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
Ok, I'm approaching what I want, I still need to practice:
The idea is to lower the brightness
Original:
What I'm working on:
The way: using the brush, in almost transparent mode, down from pure white to below 50% brightness, I think that the right word for the brush mode is Luminosity.
It's useful also to kind of hide a slight burned in specular effect, example from this:
To this:
Not perfect but still better
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
ghostship2 posted at 1:54 AM Thu, 18 May 2023 - #4465645
Well, I did, once upon a time, know more about repairing a spectrum analyzer than you might. But I don't think there's anything about Poser that I know better than you. [grin]@Thalek I’m sure there are things you know or can do that I don’t or can’t. I didn’t have much time today to respond here with more articulate answers so I can see not following this convo.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
Yes, this is a cross post I thought it best to post this in my skin shader thread AND this one.
Y-Phil had a valid point about the eyebrows being to diffuse and not saturated enough. I think I've come up with a solution. The invert and Brightness/contrast nodes exclude/modulate the roughness for the eyebrows. Have a look
I love your idea, which I'm mixing with mine: the ability to tint slightly the brows:
I've noted that your idea gives a better result near the lacrimal: in the green circle there's some specular which I find wrong, on the left: no specular effect.
Thank you "Uncle Ghostship" 😁
Note that my setup uses a second layer, to give some slight effect on the skin, easier to control with my toolbox
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
It started with a statement: shiny eyebrows are weird
And this is because I'm using a second layer to add some glossiness to the skin.
So that I started to create a "Brows Transparency Map"
Sometimes, the actual Face's Bump map is correct, but that's how I've found that numerous ones are frankly incorrect near the brows.
So, I create a decent one using a diffuse map, and I use it a this kind of setup:
Hence the result
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
