Thu, Jan 30, 7:28 PM CST
Renderosity Forums / Poser 13
Welcome to the Poser 13 Forum
(Last Updated: 2025 Jan 29 7:34 pm)
Subject: Show your Poser 13 renders!
hborre ( ) posted Fri, 02 June 2023 at 12:08 PM
Online Now!
The figure is pulling up the dingy from the water.
GiveitUp ( ) posted Fri, 02 June 2023 at 3:54 PM
Thanks hborre...
sfi4Siq1kK5PxmHs9j757R880tr7pCoN26xgennY.jpg68 layers fog shader. Rendering time approx. 45 minutes!!! I stopped this test after 12 minutes... too impatient.
GiveitUp ( ) posted Fri, 02 June 2023 at 3:55 PM
GiveitUp ( ) posted Fri, 02 June 2023 at 4:10 PM · edited Fri, 02 June 2023 at 4:10 PM
In the 68 layers cube, Alyson and
Gozilla?!.
Render aborted after about 25 minutes. The remaining pixels look a bit like dust that the lizard kicked up.
GiveitUp ( ) posted Fri, 02 June 2023 at 4:11 PM
Aaaaahhh and a Mitzubishi Lancer???
GiveitUp ( ) posted Fri, 02 June 2023 at 4:13 PM
Gozilla doesn't like the render at all. His eyes and claws go whistle...
hborre ( ) posted Fri, 02 June 2023 at 5:01 PM
Online Now!
Now, where did I place that cube?
GiveitUp ( ) posted Fri, 02 June 2023 at 5:21 PM
jwMQ3tbVqIIIyUMU3FVm6MtDNsmHGl39kkPrk1JM.jpgI will post instructions for the cube. But I don't want to hear complaints when someone's graphics card burns out.
GiveitUp ( ) posted Fri, 02 June 2023 at 5:59 PM · edited Fri, 02 June 2023 at 5:59 PM
From the Morphing Primitives participate a Square. You take that as a parent!!!!
Then you add a square rotated 90 degrees in the x axis. You set this up with a transparency of 1.1 - 1.2 or 1.3. Then duplicate it and set it "in front" in the z-axis 10 to 20 mouse clicks on the positioning wheel. Don't forget to assign it to the parent. I have no idea if it takes this setting with you when you duplicate it. So, you do that about 60 to 70 times. :)
Then you have the Fog-Cube a'la Jsenwark. You can then scale, rotate, etc. via the parent. By scaling you can influence the density of the cube. and of course by adjusting the transparency of the squares. it should always be above 1.1 the sqares don't need any color or texture, i just included them for illustration. Red for parent, blue for the "kids".
CclbZK4pkbPvqHndI99feU6A31gfN6scep9jMSQW.jpgI can promise that the fog effects are just crazy. The denoiser even makes it look like billowing clouds. !! Look the last Godzilla pic.
GiveitUp ( ) posted Fri, 02 June 2023 at 6:01 PM
For anyone who wants to try this, I express my sympathy for their graphics cards.
GiveitUp ( ) posted Fri, 02 June 2023 at 6:16 PM
Sorry... the transparency falloff is 0.4 - 0.6... important.
GiveitUp ( ) posted Fri, 02 June 2023 at 6:50 PM
Content Advisory! This message contains violence
9h0gP2hqfplNLWxYkRkkxE3d0v0QZkXDQr66zIoH.jpgLast example, Alyson frozen. First layer is broken glass (VincBagna)
GiveitUp ( ) posted Fri, 02 June 2023 at 7:09 PM
For the lighting, I recommend the round cube or another object with the warm led by VinceBagna. Place it best above the scene. Trying out is announced. Normal lighting is difficult to use, it's like in a car when it's foggy, high beam on and you can't see anything anymore...
ChromeStar ( ) posted Fri, 02 June 2023 at 9:40 PM
That looks great, but it seems like a lot of trouble to simulate a volume, when Superfly can do actual volumes....
GiveitUp ( ) posted Sat, 03 June 2023 at 2:47 AM
Show me an example that looks really good. I haven't seen anything here yet.
GiveitUp ( ) posted Sat, 03 June 2023 at 3:26 AM · edited Sat, 03 June 2023 at 3:26 AM
mjuZoNMnEhd1j63Vi3t6YSxJkuLdHeaIblP5EZ2M.jpg.
GiveitUp ( ) posted Sat, 03 June 2023 at 5:12 AM
Afrodite-Ohki ( ) posted Sat, 03 June 2023 at 11:40 AM
JanusJsenwark posted at 2:47 AM Sat, 3 June 2023 - #4467015
Soft volumetric lighting, from my product Level Up! Superfly, that has been in store since 2021. That's a P12 render.
Feel free to call me Ohki!
GiveitUp ( ) posted Sat, 03 June 2023 at 4:27 PM · edited Sat, 03 June 2023 at 4:28 PM
d8SIpcItPcUuVjx1AZrft7imnJHYlgT0K5SBcZnn.jpgOk looks interesting but can your shader also do something like that?
Rhia474 ( ) posted Sat, 03 June 2023 at 5:08 PM · edited Sat, 03 June 2023 at 5:11 PM
It's a prop. It scales, it moves...you can move it to the back as you want, and has three density settings to play with.
Here, quick render to show a lion at dawn with Medium settings on Volumetric prop, rendered in about 75 seconds on my old machine: j1EXsR7wVxaJB92VeaRrUBEWwH55SCm2OcN8BqX8.png
GiveitUp ( ) posted Sat, 03 June 2023 at 5:11 PM
ghostship2 ( ) posted Sat, 03 June 2023 at 5:31 PM
Kitbash Catwoman
Rhia474 ( ) posted Sat, 03 June 2023 at 5:36 PM
Kitbashes are the best.
ghostship2 ( ) posted Sat, 03 June 2023 at 6:02 PM · edited Sun, 04 June 2023 at 7:04 AM
@JanusJsenwark cube with Scatter Volume. 259 seconds to render
722 ( ) posted Sat, 03 June 2023 at 6:18 PM · edited Sun, 04 June 2023 at 7:04 AM
ghostship2 posted at 6:02 PM Sat, 3 June 2023 - #4467065
Scatter Volume ???? what ?? if you could show how the material looks i would ap it.
ghostship2 ( ) posted Sat, 03 June 2023 at 6:31 PM · edited Sat, 03 June 2023 at 6:31 PM
@722 Sure
You have to adjust density depending on how big your cube/object is.
ghostship2 ( ) posted Sat, 03 June 2023 at 9:46 PM
here is the cube using scatter volume this took 297 seconds
lsauvage ( ) posted Sun, 04 June 2023 at 3:34 AM
JanusJsenwark posted at 1:54 PM Wed, 31 May 2023 - #4466802
Here is the carpet.... and a million tons of other things.
https://archive3d.net/?a=download&id=f26c3727
Thank you for this gold mine :)
hornet3d ( ) posted Sun, 04 June 2023 at 5:15 AM
ghostship2 posted at 5:31 PM Sat, 3 June 2023 - #4467060
Kitbash Catwoman
Nothing short of breathtaking, I really do admire your skills.
Y-Phil ( ) posted Sun, 04 June 2023 at 5:20 AM
Kitbash Catwoman
Wooow ❤
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
Y-Phil ( ) posted Sun, 04 June 2023 at 5:22 AM · edited Sun, 04 June 2023 at 5:22 AM
722 posted at 6:18 PM Sat, 3 June 2023 - #4467066
Seems like you both forgot to tag the nudity (and the only I've problem with is... mine Zl3Amnvvwd1nP8IoQs15mhL0auddrugVcHE69loQ.gif)
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
GiveitUp ( ) posted Sun, 04 June 2023 at 5:47 AM
ghostship2 posted at 9:46 PM Sat, 3 June 2023 - #4467088
Looks very good. Unfortunately I don't have the slightest idea how something like this is made in Poser. That's why my self-made fog cube.
ghostship2 ( ) posted Sun, 04 June 2023 at 9:05 AM · edited Sun, 04 June 2023 at 9:06 AM
JanusJsenwark posted at 5:47 AM Sun, 4 June 2023 - #4467103
You have to adjust the density depending on how big the object is and the effect you want. Note that it's plugged into the VOLUME port, not the surface port.
Rhia474 ( ) posted Sun, 04 June 2023 at 9:54 AM
Works really good, will play with it today. Yay, scatter volume! Thank you, ghostship2, again.
ghostship2 ( ) posted Sun, 04 June 2023 at 10:01 AM
Volumetric smoke exhale
Rhia474 ( ) posted Sun, 04 June 2023 at 11:44 AM
Do you put that on a cone?
Nevertrumper ( ) posted Sun, 04 June 2023 at 11:55 AM
The only thing I really don't like about Bella is, that there is actually not much to do about her. Tweaking her body shape a little bit, maybe?
There is no other out of the box figures in Poser or DAZ studio with that high quality of expressions.
ghostship2 ( ) posted Sun, 04 June 2023 at 12:33 PM · edited Sun, 04 June 2023 at 12:33 PM
Rhia474 posted at 11:44 AM Sun, 4 June 2023 - #4467119
I made the prop in Blender from a tutorial about making clouds. It was a cone with a bunch of baked in modifiers.
Y-Phil ( ) posted Sun, 04 June 2023 at 12:34 PM · edited Sun, 04 June 2023 at 12:38 PM
Wooow... Thank you so much God, sorry Ghostship! 12mRUtJwEHYQAojUTc4jlT6m1sHqN8K6SRS3rNU7.gif
Smoke + fog + weird place = don't really want to know what's happening there... lol
And yes: smokes are 3D objects, I'm done with those fake plans... Yay ❤ 78" to compute using Poser's optix ultra caustics preset, on my aging 2080.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
ghostship2 ( ) posted Sun, 04 June 2023 at 12:37 PM · edited Sun, 04 June 2023 at 12:39 PM
Y-Phil posted at 12:34 PM Sun, 4 June 2023 - #4467131
Looks good! I'd make the clouds texture a bit larger (more billowy) Use the scale parameter on that clouds node
Y-Phil ( ) posted Sun, 04 June 2023 at 12:57 PM
ghostship2 posted at 12:37 PM Sun, 4 June 2023 - #4467133
Aha... you're right, thank you!
Next: find a way to modulate the scale of the vertical smoke with... something linear... Could be fun
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
ghostship2 ( ) posted Sun, 04 June 2023 at 1:21 PM
Y-Phil posted at 12:57 PM Sun, 4 June 2023 - #4467135
The smoke coming out of the urn should be scaled up as well. Might also want to lower the emission levels for the smoke. That really depends on the lighting. In the example I show I'm only using the background to light the scene
Y-Phil ( ) posted Sun, 04 June 2023 at 1:26 PM
ghostship2 posted at 1:21 PM Sun, 4 June 2023 - #4467136
I wanted some "radio-active" effect, reason why I  dropped a spot beaming up @1500%
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
GiveitUp ( ) posted Sun, 04 June 2023 at 1:42 PM · edited Sun, 04 June 2023 at 1:42 PM
Many, many thanks for your great help.
And also thanks for the fact that nobody laughed at me for my self-made Fog Cube... :)
New worlds are opening up for me... Thanks!!!
FlkHPkuNuJvTNAdpeCZsFilyZjYaBnkU2sHC6hah.jpgpiR0nQKe55L4uhVj1Smv82N9bBlqz39dHtCinAze.jpg
"Clouds" modeled in sculptris
ghostship2 ( ) posted Sun, 04 June 2023 at 1:59 PM
JanusJsenwark posted at 1:42 PM Sun, 4 June 2023 - #4467138
Looks great! Glad I could help!
Y-Phil ( ) posted Sun, 04 June 2023 at 4:19 PM · edited Sun, 04 June 2023 at 4:20 PM
Ok: two vertical smoke objects, with small differences in their parameters + vertical orientation, a witch, and now I'm happy with the result lytF5XLZ9xXQ8tDAnSmYpQN6ztpMszynTbwgPpeW.gif
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
RedPhantom ( ) posted Sun, 04 June 2023 at 5:31 PM
Site Admin
Y-Phil posted at 4:19 PM Sun, 4 June 2023 - #4467150
That looks awesome. The original, with the smaller smoke texture made me think of magic pouring out
RedPhantom ( ) posted Sun, 04 June 2023 at 5:33 PM
Site Admin
All this talk of fog and smoke and I decided to try one
ghostship2 ( ) posted Sun, 04 June 2023 at 8:39 PM
RedPhantom posted at 5:33 PM Sun, 4 June 2023 - #4467154
Nice!
Thalek ( ) posted Sun, 04 June 2023 at 10:41 PM
Online Now!
JanusJsenwark posted at 7:59 AM Mon, 29 May 2023 - #4466656
The carpet again... the HighRes tablecloth... the ball... doesn't look the way I wanted it to, but I'm out of breath now. Maybe later...
Thank's TheAnimaGemini...
That is one versatile carpet!.  And your uses of existing primitives is quite creative, as well.
