The software is no longer referred to as Poser Pro 11, it's just Poser 11 now.
By external, are you referring to a separate Library window interface? If that is the case, you need to undock that window from the main UI and make certain that you make it floating from the contextual menu. If you are referring to something else then your question is rather ambiguous and you need to elaborate further to be clearly understood.
I do not think Poser 11 has the ability to have the library external like the Pro versions could do.
no. Poser 11 can't do an external. That feature was removed when they moved away from flash/air for the library. IIRC there was a way to open the library in a browser to simulate an external library, but I don't remember the path
You might check out this https://www.renderosity.com/forums/comments/4304417/permalink to see if it works
It worked, thank you very much, and thanks to you all!You might check out this https://www.renderosity.com/forums/comments/4304417/permalink to see if it works
Hi to everyone,
i've started to work on Poser Pro 11, my last Poser was Pro 2014 and in that there was the option to make the Library external to the software, not inside it.
Is it possible also in Pro 11? i searched about that option in the preferecnes, but there isn't, maybe there are other ways?
Thank you.
