Thu, Jan 2, 8:35 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 01 5:26 pm)
Subject: Poser Pro 11 external library?
giotim ( ) posted Mon, 17 July 2023 at 10:05 AM · edited Thu, 02 January 2025 at 8:27 AM
Hi to everyone,
i've started to work on Poser Pro 11, my last Poser was Pro 2014 and in that there was the option to make the Library external to the software, not inside it.
Is it possible also in Pro 11? i searched about that option in the preferecnes, but there isn't, maybe there are other ways?
Thank you.
hborre ( ) posted Mon, 17 July 2023 at 11:33 AM
The software is no longer referred to as Poser Pro 11, it's just Poser 11 now.
By external, are you referring to a separate Library window interface?  If that is the case, you need to undock that window from the main UI and make certain that you make it floating from the contextual menu.  If you are referring to something else then your question is rather ambiguous and you need to elaborate further to be clearly understood.
Sunfire ( ) posted Mon, 17 July 2023 at 12:56 PM
I do not think Poser 11 has the ability to have the library external like the Pro versions could do.
Sunfire's Creations
RedPhantom ( ) posted Mon, 17 July 2023 at 2:06 PM
Site Admin
no. Poser 11 can't do an external. That feature was removed when they moved away from flash/air for the library. IIRC there was a way to open the library in a browser to simulate an external library, but I don't remember the path
RedPhantom ( ) posted Mon, 17 July 2023 at 2:10 PM
Site Admin
You might check out this https://www.renderosity.com/forums/comments/4304417/permalink to see if it works
giotim ( ) posted Mon, 17 July 2023 at 3:26 PM
RedPhantom posted at 2:10 PM Mon, 17 July 2023 - #4470397
It worked, thank you very much, and thanks to you all!
