Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 01 3:49 pm)
I can't say every D-force model will work as dynamic, but at least some can. When I did it, I just exported from Daz as an obj and imported it into Poser. It worked well.
There's also a couple of converters that will convert .duf to obj, if some reason you can't or don't want to install DAZ Studio.
The main issue i've run into is that DS allows layered garments. A dress with an attached petticoat, say. With Poser, they have to be two separate objects to work right. Though the sim will usually still run, there will be pokethrough.
I've had some decent results licensing Poser conforming clothing into dynamic by importing the .obj .
can models intended for dForce be exported into mesh to then be manipulated in the Poser cloth room?
In other words, can .duf be saved or transmuted into .obj?
What about all the Genesis clothing?
And is it permitted to do so, to be used in renders (not for selling the mesh!)
::::: Opera :::::
