Sat, Jan 4, 5:46 PM CST
Renderosity Forums / Poser 13
Welcome to the Poser 13 Forum
(Last Updated: 2025 Jan 03 9:11 am)
Subject: Slowdown in Poser 13.1.449 in some cases
Y-Phil ( ) posted Sun, 20 August 2023 at 11:53 AM · edited Sat, 04 January 2025 at 5:45 PM
Your experience may vary, but on my system, using my nvidia RTX2080Ti, there's a HUGE slowdown in computing, when I compare the same scene computed with Poser 13.0.339 and this new 13.1.449 version, at least when ScatterVolume is used.
Here's the scene:
Kalewksi's RKDungean3, a vase using a procedural material, 4 spheres on the ceiling + 1 in the vase (light emitters), a smoke object and a huge cube (using ScetterVolume as I still don't understand how to correctly use the new PrincipledVolume).
The settings I've used are the default "OptiX high" except that the pixel samples are set to 20 instead of 25 and the bucket size set to 2048
Poser 13.0.339: ~45 seconds using OptiX and ~59 seconds using GeForce
Poser 13.1.449: ~211 seconds using OptiX and ~264 seconds using GeForce
Without the Fog cube and the Smoke objects (both ScatterVolume)  both Poser are computing the scene below 15".
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
Y-Phil ( ) posted Sun, 20 August 2023 at 1:11 PM · edited Sun, 20 August 2023 at 1:11 PM
I've found a culprit: the Clouds node, avoidable using the new PrincipledBSDF.
Using these settings:
I like the new smoke, more convincing H8V8xpzyXH9J8ClzfDQVee5J6vT8BI6KmmM7BaC8.gif
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
Rhia474 ( ) posted Sun, 20 August 2023 at 1:29 PM
Great find, saving that matsetup. Thank you!
Y-Phil ( ) posted Sun, 20 August 2023 at 1:43 PM
Rhia474 posted at 1:29 PM Sun, 20 August 2023 - #4473125
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
petrusvitus ( ) posted Fri, 08 September 2023 at 2:33 AM
How you create the smoke... or where to buy ? sorry out topic.
Y-Phil ( ) posted Fri, 08 September 2023 at 4:34 AM
petrusvitus posted at 2:33 AM Fri, 8 September 2023 - #4474223
I'm not able to create such objects. I've bought it on turbosquid as I haven't found what I was looking for here
https://www.turbosquid.com/3d-models/3d-smoke-pack-25-1491997
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
petrusvitus ( ) posted Fri, 08 September 2023 at 5:53 AM
Thanks for the info. That smoke can be animating in poser?
Y-Phil ( ) posted Fri, 08 September 2023 at 6:11 AM
petrusvitus posted at 5:53 AM Fri, 8 September 2023 - #4474230
They are static objects, but you may modify them in Poser using the morphing tool or in Blender, for example.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
petrusvitus ( ) posted Fri, 08 September 2023 at 8:47 AM · edited Fri, 08 September 2023 at 8:51 AM
I  see. how do you make the material. Can you share screen shot. Thanks in advance..
Y-Phil ( ) posted Fri, 08 September 2023 at 9:07 AM · edited Fri, 08 September 2023 at 9:07 AM
I really don't master correctly Poser13's new PrincipledVolume, but here an example to start with
The bright contrast node helps me to have the same color but darker
If the emission strength is too high, you'll end up with nothing to see
In the example below, I've setup a vase with a strong blue source spot (1000%)
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
petrusvitus ( ) posted Fri, 15 September 2023 at 2:20 AM
Thanks for share.. Now I can make cloud with it.
Y-Phil ( ) posted Fri, 15 September 2023 at 6:14 AM · edited Fri, 15 September 2023 at 6:14 AM
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
