(Last Updated: 2024 Sep 18 10:22 am)
I've found a culprit: the Clouds node, avoidable using the new PrincipledBSDF.
Using these settings:
I like the new smoke, more convincing
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Win11 on i9-13900K@5GHz, 64GB, RoG Strix B760F Gamng, Asus Tuf Gaming RTX 4070 OC Edition, 1 TB SSD, 6+4+8TB HD
👿 Mac Mini M2, 16GB, 500GB SSD
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
Rhia474 posted at 1:29 PM Sun, 20 August 2023 - #4473125
You're welcomeGreat find, saving that matsetup. Thank you!
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
petrusvitus posted at 2:33 AM Fri, 8 September 2023 - #4474223
I'm not able to create such objects. I've bought it on turbosquid as I haven't found what I was looking for hereHow you create the smoke... or where to buy ? sorry out topic.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
petrusvitus posted at 5:53 AM Fri, 8 September 2023 - #4474230
They are static objects, but you may modify them in Poser using the morphing tool or in Blender, for example.Thanks for the info. That smoke can be animating in poser?
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
I really don't master correctly Poser13's new PrincipledVolume, but here an example to start with
The bright contrast node helps me to have the same color but darker
If the emission strength is too high, you'll end up with nothing to see
In the example below, I've setup a vase with a strong blue source spot (1000%)
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
Your experience may vary, but on my system, using my nvidia RTX2080Ti, there's a HUGE slowdown in computing, when I compare the same scene computed with Poser 13.0.339 and this new 13.1.449 version, at least when ScatterVolume is used.
Here's the scene:
Kalewksi's RKDungean3, a vase using a procedural material, 4 spheres on the ceiling + 1 in the vase (light emitters), a smoke object and a huge cube (using ScetterVolume as I still don't understand how to correctly use the new PrincipledVolume).
The settings I've used are the default "OptiX high" except that the pixel samples are set to 20 instead of 25 and the bucket size set to 2048
Poser 13.0.339: ~45 seconds using OptiX and ~59 seconds using GeForce
Poser 13.1.449: ~211 seconds using OptiX and ~264 seconds using GeForce
Without the Fog cube and the Smoke objects (both ScatterVolume) both Poser are computing the scene below 15".
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
