Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2025 Jan 08 11:18 am)
P13 as stated above. I see this as a technical forum more than a Poser 11 forum so if it belongs over in the P13 forum maybe a mod can move it over there.
---Wolff On The Prowl---
Oh I know about that Charles but I wanted to split the morph between the head and body of a figure. The split morph function doesn't have any pop that tells it where to split the morph (now that would be a cool addition to this handy script)
Oh, I didn't know that. Can you give me a little more info on how to go about doing that? Like a visual? Thanks hborre
Sure. I'm using La Femme with modified facial features as an example. This is what I created moving the facial chips around.
Make sure you're in the Pose tab of the Library. Select or create a folder you would like to save the morph. Click on the '+' icon at the bottom of the Library.
Give the morph a name on the next panel, and press the Select Subset button.
Deselect all the objects in the window and select all the body parts you want to transfer to the morph. In this example, I selected all the head parts.
Continue by clicking the 'OK' button until you get to this panel:
By default, the 'Scales' selection is checked; select 'Morph Channels' and 'Body transformation'. Continue by pressing 'OK' and in the next panel save as a single frame.
In the Library, you should get a new Pose Icon. Zero your figure and apply the new morph you created from the Library.
Another question while I got you here. How do I add or remove unwanted surfaces for an object using the Grouping tool? After my boots were auto rigged and I chose to have them Auto Grouped I now have WAY to many groups and I know many of them are empty. I don't like messy objs.
There is a side question. Is there a way to auto select a portion of a the heel? I somehow messed myself up by combining the sole and heel in my UV program but somehow the heel moved backwards at some point and I'm now just seeing it and now there is this really odd "step" and I know of NO WAY using the Morphing tool so I was hoping to split the heel and the sole back out so I could then using the Morphing tool to just move the heel back into position!
If I knew that if I fixed the obj in another program and could REPLACE the one from within Poser I'd go that route but not sure about that and I already have some really nice morphs made for the boot that I don't want to loose or have to do over again
I've used the Grouping Tool to generate Material Zones, however, you need to make those selections manually. Established object parts will show up as distinct zones automatically. But with the problem you're having, you may need to take the mesh back into an editor for proper correction. That is out of my realm of expertise, ATM.
If there is can you please instruct me how to go about doing that? Or perhaps there is a script? I'm working in Poser 13.
My Store is HERE
My Freebies are HERE
