Sun, Feb 16, 5:02 PM CST
Subject: How do you rotate a texture in a Firefly or Superfly Material?
Andrew_C ( ) posted Sun, 10 September 2023 at 3:06 PM · edited Sun, 16 February 2025 at 2:25 PM
How do you rotate a texture in a firefly or superfly material? I was trying out an old  item I have with newer textures (Maclean's Home 1) when I noticed that the woodgrain on the texture I was trying to apply was 90% to what it should be for the prop I was putting it on. I'm  pretty sure there is a way, but for some reason I havent been able to find it in the Poser manual or Renderosity forums.
Y-Phil ( ) posted Sun, 10 September 2023 at 3:26 PM · edited Sun, 10 September 2023 at 3:27 PM
The easiest way is to turn it in any (free or not) external program such as XnViewMP, which exists for Windows 7+, Mac 10.13+ and Linux
I'm often using external programs and stored the updated pics near the others, for example for the electronic devices, etc...
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
Sunfire ( ) posted Sun, 10 September 2023 at 3:27 PM
Online Now!
In the node with the texture, switch uv to vu and it should help.
Sunfire's Creations
NikKelly ( ) posted Sun, 10 September 2023 at 11:16 PM
May I recommend the free Irfan View ??
It continues to evolve and, IMHO, has a friendlier UI...
Note XNView will access Alpha ('Transparency') channel of some formats that IV cannot yet. IIRC, neither XNView nor IV can batch-extract Alpha channels...
Andrew_C ( ) posted Mon, 25 September 2023 at 5:04 AM · edited Mon, 25 September 2023 at 5:07 AM
Sunfire posted at 3:27 PM Sun, 10 September 2023 - #4474414
Thanks! Works for my purposes, and a lot easier than creating new rotated textures.
But out of interest if you say wanted to rotate a texture 45 or 30 degrees or whatever, I imagine that requires adding texture math nodes of some sort. Which one would you use and where would it go?
shvrdavid ( ) posted Mon, 25 September 2023 at 6:27 AM
Rotation of textures involves a bit of vertex math, but it is not impossible. You do have to use cycles nodes to do so, as far as I know.
This is one way you can rotate a texture, without moving the object. https://b3d.interplanety.org/en/rotating-texture-by-nodes/
EnglishBob ( ) posted Thu, 28 September 2023 at 5:40 PM · edited Thu, 28 September 2023 at 5:41 PM
Andrew_C posted at 5:04 AM Mon, 25 September 2023 - #4475225
I found this in my material room tips 'n' trix folder, credited to AntoniaTiger:
This example is shown using the Tile node, but it can equally well be applied to the U and V offset inputs of an image node. The angle is set by Value_1 of the Math_Functions_4 node (45 degrees here). Note that your image would need to be tiling for most uses.
