DAZ|Studio F.A.Q (Last Updated: 2024 Oct 21 9:46 pm)
That will not work if it is a moprh saved with a non-zero default value - Currently Used shows properties with non-default values, not non-zero values.I'd suggest going to the Shaping Tab, select the figure and at "Currently Used" option to see if something is loading dialed in.
Timberoo posted at 4:26 PM Mon, 20 November 2023 - #4477983That's why it was a suggested place to start and not framed as a definitive answer.That will not work if it is a moprh saved with a non-zero default value - Currently Used shows properties with non-default values, not non-zero values.I'd suggest going to the Shaping Tab, select the figure and at "Currently Used" option to see if something is loading dialed in.
all the figures and does not matter what one with the exception of base g8f show up as very young skinny distorted figures. I'll see if I can send a render .
