Sun, Oct 6, 6:59 AM CDT
Renderosity Forums / Poser 13
Welcome to the Poser 13 Forum
(Last Updated: 2024 Oct 05 2:34 pm)
Subject: Cycles based SSS skin shader
ghostship2 ( ) posted Tue, 05 September 2023 at 6:23 PM
@Bastep that  looks great! BTW I always use your background preset freebee
Bastep ( ) posted Wed, 06 September 2023 at 1:14 AM
Thanks @all
Have a great day
RAMWorks ( ) posted Mon, 19 February 2024 at 11:56 AM · edited Mon, 19 February 2024 at 11:58 AM
I'm back.  So I'm having a devil of a time getting any detail to show from either a bump or normal map using Cycles.
Here is a partial screen grab of what I have set up.  You notice to the left there is a bit of skin color, well that's the render results.  FLAT.  The Normal map has allot of good detail so I must be doing something wrong.  Wondering if I should use the Displacement input in the Cycles Root node to get details to pop?
PS, the low input strength number seems to work fine on areas like the lips or face but on the body even set to 1.000000 still gives me know detail. I don't have this issue at all with the Poser Root Node nor the Physical Root Node. I'm using the latest Poser 13
---Wolff On The Prowl---
My Store is HERE
My Freebies are HERE
RAMWorks ( ) posted Mon, 19 February 2024 at 1:07 PM
Never mind, figured it out!
My Store is HERE
ghostship2 ( ) posted Mon, 19 February 2024 at 1:20 PM
@RAMWorks. Was that a skin shader? No SSS at all on that (set to 0)
hborre ( ) posted Mon, 19 February 2024 at 1:39 PM
Your color space on the image node should be set to '_builtin_raw' for black & white, grayscale, or normal maps.
RAMWorks ( ) posted Mon, 19 February 2024 at 4:34 PM
OK.  Thank you
My Store is HERE
RAMWorks ( ) posted Mon, 19 February 2024 at 4:38 PM
OH, I did update the image node to the default one that's not native to Cycles, which has always worked for me.  So that node you see above is gone with the older Image node replacing it.
My Store is HERE
