Wed, Feb 19, 1:56 PM CST
Forum Moderators: RedPhantom
Subject: fitting clothes to teen morph.
mr_red ( ) posted Sat, 16 March 2024 at 4:02 AM · edited Sun, 16 February 2025 at 12:42 PM
I have just got this figure morph for v4 called teen Becky.
xWMFG2HVHslRoJ2OAGIjiJV2uBOnISCzYUwp2RD3.jpgI have got rid of that annoying dullness on the skin ok but finding it difficult to fit clothes. I tried scaling the clothes (above) and that sort of works and i have tried applying the morph to the clothes (not so good) what are the best ways to do this. i am not so good using cloth room tools so looking for something quick and easy.
RedPhantom ( ) posted Sat, 16 March 2024 at 7:07 AM
Site Admin
Rather than scaling the close, you might try the include scales option on the properties pallet. Usually, I use copy morphs and then use the morph brush to touch it up. Not seeing your results I'm guessing I'd start with the smooth brush and then use the tighten or loosen fit brushes. The key to using the brushes is adjusting the magnitude. Many are set too high.
mr_red ( ) posted Sat, 16 March 2024 at 7:24 AM · edited Sat, 16 March 2024 at 7:24 AM
so will that mean i have to save every bit of clothing to use on this figure in a new folder?  as a comic creator i like things to be used as quick as possible. and how do you copy morphs? never come across that
hborre ( ) posted Sat, 16 March 2024 at 9:00 AM
Which Poser version are you using?
mr_red ( ) posted Sat, 16 March 2024 at 9:05 AM
i use poser 11 and always render with firefly
RedPhantom ( ) posted Sat, 16 March 2024 at 9:23 AM
Site Admin
To copy morphs, have your clothing selected then use Figure>Copy Morphs and then in the copy from the pallet, choose Vicky and hit okay. A list of morphs will pop up and pick out the ones you want.
As far as using the clothing for your character, you have 2 choices you can either save the clothing with the morphs once converted or you can copy the morphs each time.
If this character uses a bunch of morphs, like several morphs++, you can condense them down into one morph and save the character that way to make it quicker to copy morphs to clothing. That's what I do for my stories. It may be a little more advanced, but I can help you with it if you want.
DingDong2024 ( ) posted Sat, 16 March 2024 at 10:32 AM · edited Sun, 17 March 2024 at 10:38 AM
Here is a tutorial, including Inj-Rem scripts for autofit
mr_red ( ) posted Sat, 16 March 2024 at 10:42 AM
I will have a play. thanks for the help peeps
mr_red ( ) posted Sat, 16 March 2024 at 1:44 PM
got it sorted, although not fully happy with the figure and every new pose the hair goes out of whack and needs reposing but ho-hum.
hborre ( ) posted Sat, 16 March 2024 at 2:04 PM
Is the hair conforming or a prop?  If it is a prop, you will need to parent it to her head.
mr_red ( ) posted Sat, 16 March 2024 at 2:10 PM
its prop hair, fine normally when used with V4 but with this it moves so i will try that thanks.
Zaycrow ( ) posted Mon, 18 March 2024 at 1:14 AM
For quick and dirty fix for fitting clothes I always use the Morph Tool "Tighten Fit" set goal to the character and vola :)
