Forum Moderators: RedPhantom
Rather than scaling the close, you might try the include scales option on the properties pallet. Usually, I use copy morphs and then use the morph brush to touch it up. Not seeing your results I'm guessing I'd start with the smooth brush and then use the tighten or loosen fit brushes. The key to using the brushes is adjusting the magnitude. Many are set too high.
To copy morphs, have your clothing selected then use Figure>Copy Morphs and then in the copy from the pallet, choose Vicky and hit okay. A list of morphs will pop up and pick out the ones you want.
As far as using the clothing for your character, you have 2 choices you can either save the clothing with the morphs once converted or you can copy the morphs each time.
If this character uses a bunch of morphs, like several morphs++, you can condense them down into one morph and save the character that way to make it quicker to copy morphs to clothing. That's what I do for my stories. It may be a little more advanced, but I can help you with it if you want.
I have just got this figure morph for v4 called teen Becky.
