Forum Moderators: wheatpenny, RedPhantom, Deenamic Forum Coordinators: Anim8dtoon
Freestuff F.A.Q (Last Updated: 2024 Oct 01 6:00 pm)
Welcome to the Freestuff Forum. The Freestuff Forum is intended for all freestuff related postings within our community. This is a highlight area where our membership is invited to review, announce and give feedback in greater detail on various freestuff items offered. Members can also post wishes of freestuff items they would like to see.
Notice: Links to offsite 'For Sale' items will be removed
Renderosity Free Stuff Area
Free Stuff Gallery
Freebies do not appear in your account. They can be downloaded directly from the webpage to where you designate as a download folder. Each file will need to be opened with a compression program and the content installed into a Poser runtime. If done properly, the content will appear in its designated category. However, not all freebie files are organized in the proper hierarchy order for direct installation which presents a major problem when finding content in the Library.
“ However, not all freebie files are organized in the proper hierarchy order for direct installation which presents a major problem when finding content in the Library.
hborre, any suggestions welcome. I’ve read several times your mini-tutorial on organizing library and I’m going to ask some questions to clarify my thoughts on how to do mine!
Visual inspection of the zipped content. If the top folder in the hierarchy is entitled 'Runtime', you should be able to install the content from within Poser. However, I am not familiar with MACs but I know that some time ago iOS did not allow folder merging, it replaced everything with the new content. Please verify if this is no longer the case.
Depending on the age of the OS the Mac allows merging, however, the computer gods may not be friendly on the day you do it and will send them elsewhere. I manually open the zips > then go to the inside folders to runtime > and go one folder at a time, putting the items within into the exact matching folder on the Poser folder where the runtime is located...or if you have an external runtime then again match the folders with the same one on the Poser program..
I forgot that grabbing items from the free section does not show up in your account, sorry about that.
well on my possessed mac, it tends to have a life of its own...iMac and it knows I am stuck with it. IF I leave poser open when installing the zips it tends to not show them until I restart it.
another thing is to compare what it says should be in there with the items...make sure it is .pp2 then take the one from the zip and plop it into that exact same folder...then see if that works
I forgot that to make sure you have LaFemme 2 also
For some reason, this screencap does not look right. Retake this screencap with a wider view and describe exactly how you installed the ear buds.I found them:
it shows them in the runtime/libraries/props/ear pods folder but..
...why don't they show up in my props folder?
mystery almost solved, Sherlock?
drawn
As hborre said, you need to unzip these files. If they were downloaded from the freestuff here, and are relatively new, (by relatively new, I mean at least as far back as La femme came out) the testers check to make sure the runtime structure is correct. I asked one of the testers. This means you can use the install from zip option in Poser. To do this in Poser, go to file and click on install from zip archive
A window will pop up asking you what to install. Select the file you want to install and hit open
A new window will pop up asking you where to put the content.
You have 2 choices, a runtime or other. I recommend a runtime(that should be the default)
You also have the option for which runtime to use. The default is downloads. Let's use it for this time so we're all on the same page
hit install.
Now, in your library, go to which category you want, (figures, props etc) and open the downloads runtime
hit the refresh arrow for the item to show up.
It should now be installed.
As a side note, I see you have some of Nemesis's backgrounds downloaded. Keep in mind these are 2D images and not Poser content. They can be used in Poser, but not installed the way I described above. It's a little more advanced so let's save that for another time so you don't get confused.
hborre wrote: "I see many unzipped folders on your drive. Have you merged any content runtime folder with a Poser runtime folder linked to your Library? Otherwise, you will need to link every content runtime to your Poser Library, which is something I would not recommend."
me: JUST HOW do you see unzipped folders? I see no attached .zip anywhere? how do you know them? and how would I like the contact runtimes to Poser Library? and why do not think that's a good idea?
REd, I only understand what you're saying because I speak English, but otherwise it's mostly gab, gab, gab. I always tell Poser to install zipped files but I cannot correctly guide it to where to look (download folder) and cannot identify the files, and after it does (something?) I cannot see any results in Libraries...
thanks, guys.
drawn
https://www.renderosity.com/gallery/items/3156119/install-from-zip here's a video showing how to install your freebies.
A fine presentation. Unfortunately, there are Freebie vendors that do not adhere to the Poser hierarchy conventions in their zipped files. Instead of using runtime as a primary folder, they nest it within a content or title folder that confuses the Poser Zip Installer. On many occasions, I have corrected the hierarchy structure to conform with Poser's standard setup.
According to the testers, they are checking that for now and requiring proper file structure. Older things may still have a problem, but one step at a time.
I downloaded some freebies, including Red Phantom's AirPods, and now that I want to put them on my la femme, I can't find them in props. did I load them? can't see them. sorry, this is basic stuff but I'm a rank newbie, wet.
drawn
