Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 30 7:24 pm)
I had, but I tried again and no luck
It may not be related but: I'm getting the same effects, from time to time, for example when I conform a hair (or a cloth) character to a smaller-than-the-default Vic4, and the include scales isn't helping: I have then to uncheck it and play with the hair's global scale till it gets in place correctly.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Win11 on i9-13900K@5GHz, 64GB, RoG Strix B760F Gamng, Asus Tuf Gaming RTX 4070 OC Edition, 1 TB SSD, 6+4+8TB HD
👿 Mac Mini M2, Sequoia 15.2, 16GB, 500GB SSD
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
The reason you need to uncheck follow origins is because the dependencies are baked into the clothing when you copy from the regular figure in the scene. When the morph is applied the origins and scales are already matched.Then they get matched again by the included in conforming options and it explodes. If you copy from a developer rig they don't have the dependencies setup. You're clothing will need "Follow origins" checked like is normally expected. You should get a better morph transfer too as the dev rigs have a higher resolution base mesh.
This is why we still need developer rigs.
Most of that was Greek to me, but I understood the right parts and it works now. Thanks!
I'm creating a pair of boots for Lafemme2 and am having trouble with adding the BodyFX morphs. When I apply the nanism morph, I get this.
With these checked on the boots
If I check the follow origins, they work fine but then the short morph looks like this
I need to uncheck the "follow origins" to get those to work. How can I get it so they work with the same settings? I've tried matching centers to morph but that doesn't help.
