Sat, Jan 18, 1:35 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 18 10:25 am)
Subject: Morph issues
RedPhantom ( ) posted Thu, 04 April 2024 at 11:14 PM · edited Sat, 18 January 2025 at 7:00 AM
Site Admin
I'm creating a pair of boots for Lafemme2 and am having trouble with adding the BodyFX morphs. When I apply the nanism morph, I get this.
With these checked on the boots
If I check the follow origins, they work fine but then the short morph looks like this
I need to uncheck the "follow origins" to get those to work. How can I get it so they work with the same settings? I've tried matching centers to morph but that doesn't help.
hborre ( ) posted Fri, 05 April 2024 at 9:05 AM
Did you try "Copy Joint Zones From..."?
RedPhantom ( ) posted Fri, 05 April 2024 at 9:15 AM
Site Admin
I had, but I tried again and no luck
Y-Phil ( ) posted Mon, 08 April 2024 at 3:06 AM
Online Now!
It may not be related but: I'm getting the same effects, from time to time, for example when I conform a hair (or a cloth) character to a smaller-than-the-default  Vic4, and the include scales isn't helping: I have then to uncheck it and play with the hair's global scale till it gets in place correctly.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
nerd ( ) posted Mon, 08 April 2024 at 1:27 PM
Forum Moderator
The reason you need to uncheck follow origins is because the dependencies are baked into the clothing when you copy from the regular figure in the scene. When the morph is applied the origins and scales are already matched.Then they get matched again by the included in conforming options and it explodes. If you copy from a developer rig they don't have the dependencies setup. You're clothing will need "Follow origins" checked like is normally expected. You should get a better morph transfer too as the dev rigs have a higher resolution base mesh.
This is why we still need developer rigs.
RedPhantom ( ) posted Mon, 08 April 2024 at 2:41 PM
Site Admin
Most of that was Greek to me, but I understood the right parts and it works now. Thanks!
