Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2024 Jul 27 12:14 pm)
Many Pose files (*.pz2) are using readSCript to load a collection of morphs/partial poses, etc...
Exemple:
So that I suppose that it should be possible to create a pose file or a props file that loads two files dropped in a dedicated place of a runtime's structure.
But I don't know if there's a tool to create this, I think that it should be easy to create it using a Python script.
PhYl.
Win10 on i7 8700K@4.3Ghz, 64Gb, Asus TUF Gaming RTX 4070 OC Edition, 2x 2Tb ssd + 6+4Tb hd + 1x 8Tb hd + 1 10T NAS, Poser 11, Poser 12 and now Poser 13
I am pretty sure this IS possible, I have a working theory, but I would need to run a few tests. In short it would involve some editing of the PP2 I believe...as Y-Phil suggests. I would need to see how much needs embedded, and where to embed. I think you might be able to embed partial pose data and a few needed lines to target a figure from a Pose of the hand into the PP2. Make backups before trying. I suggest using Notepad++ with the Poser extension for the editing.
I have done this to embed prop positioning in a figure pose with parented props for some time...but not loading the pose with the prop.
The New HD Toaster from Wamco toasts bread more evenly and acurately than Standard Toasters. Take advantage of the FULL resolution of your bread and try one today, because if your toast isn't in High Definition, you are not getting the most of your toast!
Is it possible to have a hand pose plus a smart prop added to the same hand at the same time? Daz Studio has this feature available called "wearable preset" which is like a smart prop but also allows you to pose the character at the same time. Is this feature or similar available in Poser? It would be nice.
Thanks!
davo
