Mon, Feb 10, 6:30 PM CST
Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2025 Jan 26 5:56 am)
banner
Subject: smart prop plus hand pose at same time possible?
davo ( ) posted Thu, 29 February 2024 at 1:26 PM · edited Mon, 10 February 2025 at 6:26 PM
Is it possible to have a hand pose plus a smart prop added to the same hand at the same time?  Daz Studio has this feature available called "wearable preset" which is like a smart prop but also allows you to pose the character at the same time.  Is this feature or similar available in Poser?  It would be nice.
Thanks!
davo
Y-Phil ( ) posted Fri, 01 March 2024 at 6:08 AM
Many Pose files (*.pz2) are using readSCript to load a collection of morphs/partial poses, etc...
Exemple:
So that I suppose that it should be possible to create a pose file or a props file that loads two files dropped in a dedicated place of a runtime's structure.
But I don't know if there's a tool to create this, I think that it should be easy to create it using a Python script.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
KageRyu ( ) posted Mon, 08 April 2024 at 1:41 AM
I am pretty sure this IS possible, I have a working theory, but I would need to run a few tests.  In short it would involve some editing of the PP2 I believe...as Y-Phil suggests. I would need to see how much needs embedded, and where to embed.  I think you might be able to embed partial pose data and a few needed lines to target a figure from a Pose of the hand into the PP2.  Make backups before trying. I suggest using Notepad++ with the Poser extension for the editing.
I have done this to embed prop positioning in a figure pose with parented props for some time...but not loading the pose with the prop.
The New HD Toaster from Wamco toasts bread more evenly and acurately than Standard Toasters. Take advantage of the FULL resolution of your bread and try one today, because if your toast isn't in High Definition, you are not getting the most of your toast!
Y-Phil ( ) posted Tue, 09 April 2024 at 7:23 AM
I think that it should be possible to have a pz2 file with one readscript that loads the prop and the other that loads the pose for the hand.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
