New Poser Users Help F.A.Q (Last Updated: 2025 Jan 21 6:44 am)
As Kalypso said, you'll probably need to select the chair, but also you'll find more parameters if you click on the + button near other
ok I did that, and all I get is the opportunity for some panty tease poses, which may prove useful but don't need that now!
actually, looking at this shot I realize I didn't have Other clicked, so I went back and clicked it. a blue bar appears but no dials...
Grrr, how do I change the minus sign into a plus? I haven't done it yet because I can't clearly see inside the dark box unless I screenshot it?
drawn
It's important to note that seeing a plus sign does not always indicate the presence of additional dials. Poser may display a default value even when a dial is not present.
At the moment, it's unclear whether the stool is a figure or a prop. If the stool is a figure, its main components should be conformed rather than parented to one another. To provide better assistance with this issue, please provide detailed information.
I put this chair 1 on the stage and put its legs and base under it and by lowering the seat made it appear to sit on legs, but that's all. I cannot move the whole chair in any direction (see screenshot) nor parent seat to legs or vice versa. of what use is such a prop?
are there instructions for how to control this kind of obj?
drawn
there are no transform dials to move the chair, can't even recall how I moved it from way behind fingers to in front..?
drawn
