Tue, Jan 21, 10:31 AM CST
Renderosity Forums / New Poser Users Help
Welcome to the New Poser Users Help Forum
New Poser Users Help F.A.Q (Last Updated: 2025 Jan 21 6:44 am)
Subject: new, can't move prop?
drawn ( ) posted Thu, 11 April 2024 at 4:02 AM · edited Mon, 06 January 2025 at 2:59 PM
I put this chair 1 on the stage and put its legs and base under it and by lowering the seat made it appear to sit on legs, but that's all. I cannot move the whole chair in any direction (see screenshot) nor parent seat to legs or vice versa. of what use is such a prop?
are there instructions for how to control this kind of obj?
drawn
there are no transform dials to move the chair, can't even recall how I moved it from way behind fingers to in front..?
drawn
Kalypso ( ) posted Thu, 11 April 2024 at 5:12 AM
Site Admin
It looks like this is a figure so you will need to select its Body and there you will find the Translation dials.  Right now you only have the Legs part selected.
RedPhantom ( ) posted Thu, 11 April 2024 at 6:47 AM
Site Admin
As Kalypso said, you'll probably need to select the chair, but also you'll find more parameters if you click on the + button near other
drawn ( ) posted Thu, 11 April 2024 at 9:11 AM · edited Thu, 11 April 2024 at 9:11 AM
ok I did that, and all I get is the opportunity for some panty tease poses, which may prove useful but don't need that now!
actually, looking at this shot I realize I didn't have Other clicked, so I went back and clicked it.  a blue bar appears but no dials...
Grrr, how do I change the minus sign into a plus? I haven't done it yet because I can't clearly see inside the dark box unless I screenshot it?
drawn
hborre ( ) posted Thu, 11 April 2024 at 10:22 AM
There are no additional dials under the Other selection.  That is why there is a minus sign.
drawn ( ) posted Thu, 11 April 2024 at 11:04 AM
But red showed I could click on other and get a plus sign. I’m confused now. What I do??
hborre ( ) posted Thu, 11 April 2024 at 11:56 AM
It's important to note that seeing a plus sign does not always indicate the presence of additional dials. Poser may display a default value even when a dial is not present.
At the moment, it's unclear whether the stool is a figure or a prop. If the stool is a figure, its main components should be conformed rather than parented to one another. To provide better assistance with this issue, please provide detailed information.
drawn ( ) posted Thu, 11 April 2024 at 2:41 PM · edited Thu, 11 April 2024 at 2:41 PM
well, the chair/stool is a figure and I thot a prop
and a problem to wrangle with:
but I finally Locked it and behold a unit. and move it into place
whew, thanks for your insistence on details...
drawn
